Okay I'll simplify my post.
The definitive guide for LEDs...
No.1 left/right
No.2 up/down
Sent from my piece of shite iPhone - according to Muz.
Any chance of posting a pic of the beam a certain distance from the wall (eg. 1m) so we can see what kind of height we should be aiming for?
It's not the exact height that is important here. When you place your car 10 cm form the wall, mark the height at the __/ __/ mark if you know what I mean. When you reverse your car 10 meters away, the vertical(up/down) difference between the __/ __/ marks should be 10 cm. That's the official percentage. I tend to make it 5 cm. So 10 m away from the wall the beam is 5 cm lower than it was facing the wall from the shortest distance possible.
Does this make sense or did a over complicate it?![]()
So you have set yours higher than the recommendations?
But if the initial height is off then any adjustments made 10m back would be off as well?
Really need a mate who works in a MOT garage, as if it's not set up as that, it's going to be illegal and a failure anyway.
Does it look like a failure to you?It's not blingding anybody, the beams are pointed torwards the ground and I can see a lot better, so it's better for me and the same for others.
Low beam from 45 meters away:
I would say that seems quite high... as every bump you hit will cause your lights to be blinding people. I don't see a line on the road in front of me, so would assume the lights being set any higher wouldn't have any real world benefit.
I've never heard of people raising their headlights as it should be set from the manufacture, I see a few MOT failures in about 2 years time. The internet is great for advice but sometimes the wrong people give the wrong advice, not saying this is happening here but it sure feels like it, there are somethings which you shouldn't be messing with - it's in warranty so ask your dealer to check.
), to each his own. And if someone doesn't like the way his headlights lit the road, he can give it a try, otherwise he can overlook this whole thingAll I am saying is that if you don't have proper chart on the wall at the correct height, dist etc, how do you know that you have the left hand bias right to keep it in your lane. It wouldn't be a MOT failure item, if we could all set it to what we think is correct.
Because everything doesn't need to be 10000000% accurate to work in real life. It can be 95% and it can still be better than most of the vehicles that lit the road everywhere but the road in their old crappy candel lights, pimped super Xenons, etc. Not everything has to be so complicated, spot on, 100% accurate and with some tools and a little common sense everybody can adjust it as long as the settings don't mess with safety on the road.
And while we're at it. I think that it's better to worry about this beam adjustment and at least set it about accurate then to do nothing at all and have a XYZ setting and live in a hope that it must be that way. How many of you are 100% sure that your adjustment is 100% right? Did you check it? How do you know that it's 100% optimal and it's not a threat to anybody?
What I'm trying to say that I KNOW what my settings are, I know at least about accurate, how do they lit right/left, up/down because I have measured it, adjusted it, measured it again, tested and so on and so on. I think I'm on the safer side and somebody who blindly thinks that the factory or the dealer made sure it's 100% optimal, is not.
Ok, enough written, my fingers are starting to hurt.
...... I said take it to a garage/MOT centre and get it done right.
Sounds like your an expert, and they should just abandon all the laws as everyone can do what they think is right, I would like to here that argument you just gave standing up in court, I never ever said do nothing and blind folk, I said take it to a garage/MOT centre and get it done right.
