Burnacide
Hello, i've been trying this entire weekend to search for what could have happened to my car but theres so many different things and none of them which match my fault codes and problems 100%.
Car in question is a 1.8T mk1 Leon Cupra4. (180)
So what has happened was that i was out driving and came to a steep tunnel and was boosting what the turbo is good for. then suddenly i lost all power and my dashboard litt up, EPC, ESP, check engine and i lost all power.
pushed the pedal to the floor to no avail. tried to stop the car to turn it on and off, but the idle was rough and the pedal was dead. tried to disconect the battery to see if it would reset, it did but the problem was still there.. got towed back home and i just got it scanned today. Heres the log:
Chassis Type: 1M (1M - Seat Leon (2000 > 2005))
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ2R082701 Mileage: 216260km/134377miles
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Part No: 06A 906 032 HN
Component: 1.8L R4/5VT G 0001
Coding: 10710
Shop #: WSC 01286
VCID: 71E3EB073BDE7196643-5140
VSSZZZ1MZ2R082701 SEZ7Z0A1381627
5 Faults Found:
16795 - Secondary Air Injection System
P0411 - 35-10 - Incorrect Flow Detected - Intermittent
17951 - Angle Sensor 1 for Throttle Actuator (G187)
P1543 - 35-00 - Signal too Small
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 35-00 -
17987 - Throttle Actuator (J338)
P1579 - 35-00 - Adaptation Not Started
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-A.lbl
Part No: 1C0 907 379 H
Component: ESP ALLRAD MK60 0102
Coding: 0023046
Shop #: WSC 00001 001 00001
VCID: 2F672D7FBD6A2766327-5140
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00040
Shop #: WSC 06441
VCID: 234FD14FB1A29306A6F-258E
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 1J AIRBAG VW51 0A 0004
Coding: 12618
Shop #: WSC 06441
VCID: 2241D44BAEB89A0EAD9-5106
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance Too High - Intermittent
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 822 C
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05124
Shop #: WSC 00000
VCID: 2855C663C884705EF3D-5106
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
VCID: F0E56E03B0D4F89EEBD-5124
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 C
Component: HALDEX LSC ECC 0009
VCID: 2045DE43A0B4881EBBD-4B02
1 Fault Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: 3K Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 06441
VCID: 3A710C2B2628F2CE959-4B02
Subsystem 1 - Part No: 1C0959801B
Component: 3K Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C0959802C
Component: 3K Tõrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811A
Component: 3K Tõrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812A
Component: 3K Tõrsteuer.HR KLO 0004
1 Fault Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
End ---------------------------------------------------------------------
so does anyone have any pointers as to where i can begin to look for faults?
Ok, so got around to look at the car today. took off the pipe that goes on to the throttle body and tried to see if there was any movement, could this have caused it to missalign? anyways it did not respond.
But at closer inspection, the clip that goes in to the throttlebody was loose so when that was plugged in, the car started working again. but there was one problem - the idle was rough and the throttle response feels slugish. could this possibly be fixed with a TB allignment?
Could do, if you haven't already, just try a battery reset now that it's connected up again
Okay, disconecting the battery didn't work so i went over to a mates house who has the vag com cable and got it alligned and the problem is now gone!
