Little Teaser
to do:
:funk::funk:
Does anyone know how to enable the other skins like the skoda and vw or is that impossible
back on navigon you were able to.
Try this :
create a file:
\VwBrandDevice\Settings\UserSettingsDevMode.default with notepad
with contents:
Code:
<?xml version='1.0' encoding='iso-8859-1'?>
<Settings>
	<Active>1</Active>
</Settings>
make sure it's .default
the create a file called branddevice.reg and put it to the root /.
reboot and then you maybe able to manually chose your brand/skin and unlock the think blue trainer. (All settings (route profiles, last targets...) will be lost)
if not I need to modify the branddevice.exe...
please report back
Says something about the vin missing when I put the reg file in the root? (NAVIGON E:)
Idea no. 2: lets try an old vwbranddevice from navigon.. I have that exe, but at home. I wont be there until easter, so maybe someone else can send it to you...
ok I only know a friend with a Cupra with navigon but like I say that's a cupra
It doesnt matter if its a cupra, fr, skoda or vw. All are the same. All have the same software. Only on first boot skins are changed and functions enabled. So that will work
Happened upon this site a few weeks ago, when looking for something to customize the Seat Entertainment unit - much appreciation to all contributors and looking forward to trying the skin and mod tool from robomrburns.
One query I had on what I think is the upgraded performance exe was the Gforce feature. Does that work on the MK5 Ibiza FR or is the sensor for that section not on the FR?
Hi, I enabled the Performance Display for 7.16.8
unfortunately the new Eco-Trip Menu does not show up.
DOWNLOAD
Maybe Phers version will be able to do both! :)
