Ta! Just need to find someone with that software. I have a mechanic friend, so maybe he can help!![]()
How far NE Wales are you ?
Ruthin area Deano about 5 miles from Evo triangle...
Guys
I really like the idea of the carbon effect on the Media / radio screen.
I have the tech pack with the 5.8 " screen too.
@corfyboy or anyone else, can you advise which options you amended with VCDS to switch that on.
+ 1 Deano... I don't use vag com I have access to odis vag factory software. And when giving advise to Deano we found if you don't do the reset it will not take affect and revert back, the software I use automatically does the reset for youCheers Deano, will give it a try in the morning
Select 5F ( Information Electronics )
Then coding - 07
Then click on "long coding helper"
Go down to byte 17
Un-tick bit 1
Tick bit 2
( some have had to tick and untick different bits but you need to alter the last two digits - from 01 to 10 I think )
Exit
Click "do it"
After it says code accepted - come out of all the controllers
Do a system reset - hold power button in for 30 seconds
You now have carbon background to the media unit.
Had Nigel from Uckfield come and code 10 changes for me. He's one of the few round this way with a VAG COM which he makes a living from with other car related activities. Would recommend; bit pricey ie £100 for 1.5 hours (£80 call out and the first hour) but he knew what he was doing and still cheaper than me bodging about with a cable.
Here's my list for info
Cornering fog lamps
Check battery condition
Customize consumption display to show fuel to fill
FIS carbon look in on board computer
Rear Wiper Wipe in reverse
Air blower speed
Indicator cycle 3 to 4
Door Mirrors close instantly
Pointer sweep
Ignition active message and bong deleted
but couldn't get the Media Screen to work and did try the reset trick
Cornering fog lamps
Air blower speed
Pointer sweep
Air blower speed
When you lane change indicate, it will do 4 flashes instead of 3
When in "auto" mode on the ac, it will show you how fast the fan is blowing
Shows you how much fuel you can get in when you fill up on the display.
You need to upload them to photobucket or similar. Plus I think you need 15 posts or more before you can.Fitted a rear spoiler tonight, but can't share photos....anyone help?
Your post count is to low to post pictures directlyFitted a rear spoiler tonight, but can't share photos....anyone help?
Fan Washers - Big improvement, missed them from previous car.
