What did you and your MK2 do today?
STU3Y
1,271
Kent
Ouch I would be crying if that was my car. Never a good crash to be in, as it's likely they will say the car behind pays for his repair/replacement but his insurer will pay for the car in front as the gap left wasn't big enough to prevent him being shunted into it. It's lose lose scenario. Hopefully no one was hurt that's the main thing.
-UzY-
91
Ouch damage to both ends, I would be screwing
On the subject of what did the mk2 do yday, detail clean of the exterior
Jun 25, 2012
920
Gateshead
Was it a direct swap with no modifications? How much difference has it made?
I bought the kit from a member on mk5gti forum who is currently breaking his Leon.i believe there is a small amount of fettling if you source the parts
Here the thread I used for fitting tips. http://www.seatcupra.net/forums/showthread.php?t=123171
I believe it is a stronger richer nicer sound( not tinny), I'll be interested in a side by side comparison with the OE speakers
Kyado
86
Took the soundaktor out, much prefer the sound without it!
Also gloss blacked the badge grill.
Sent from my SM-G900F using Tapatalk
Finally received my fathers day present 'Triple R Front splitter. suprised by the quality. Just need to find the time to fit it. hopefully next week. They also need to hurry up and sort the defect problem out on the rear defuser so i can get one. apparent a couple of month
Jun 25, 2012
920
Gateshead
^^^^Hmmm want!^^^^
Iv been busy putting parts together for a Big brake upgrade.
Vagbremtechnic TTRS/DB9 caliper carrier for standard size discs,
TTS j-hooked discs (not pictured)
10mm H&R hub centric spacers
Just need to get some HEL lines,extended studs,calipers(not decided) and pads not decided either
Treat my keys to some cupra key rings as well,
