Is my ecu shot?
sockpuppet
837
So after a bang and smoke coming out from somewhere underneath the battery bay, my initial thought was the starter had shorted out or possibly the fan control module had shorted.
I get the glow plug light flashing when turning the key to the on position and when I try to turn the car over there is a click (doesn't turn over) and the alarm goes off.
I scanned with Vagcom and there is a large amount of errors:
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 KG
Component: 1,9l R4 EDC 0400SG 5342
Coding: 00102
Shop #: WSC 06402
3 Faults Found:
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-00 - -
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0022017
Shop #: WSC 00001
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 922 E
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 04404
Shop #: WSC 00222
VSSZZZ1MZ5R085045 SEZ7Z0E3082693
1 Fault Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
No fault code found.
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 06402
7 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01331 - Door Control Module: Driver Side (J386)
49-10 - No Communications - Intermittent
01332 - Door Control Module: Passenger Side (J387)
01359 - Internal Central Locking Switch: Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
01333 - Door Control Module: Rear Left (J388)
01334 - Door Control Module: Rear Right (J398)
sockpuppet
837
Kline comms? Do you mean my diagnostics software (vagcom 3.11) or the car comms?
sockpuppet
837
I think I have solved it. The error codes were due to the starter motor short circuiting and messing the electrics up.
I replaced the starter motor and then cleared the error codes, I still get excessive comm errors from block 8 and can't read 17, but I think Bill is right about it being my diagnostics comms.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
18
glos.uk
pulling instrument cluster fuse can quieten down comms if wanting to talk to engine ecu only sometimes
sockpuppet
837
Thats good to know for future reference. I got to the bottom of the comms issue and sucessfully read blocks 8 and 17 and they are cleared of errors. Ecu is now reading with no faults.
RichyH
278
Lincoln, UK
What was the issue in the end then? Having the same trouble, can't seem to find a solution
