So after a bang and smoke coming out from somewhere underneath the battery bay, my initial thought was the starter had shorted out or possibly the fan control module had shorted.
I get the glow plug light flashing when turning the key to the on position and when I try to turn the car over there is a click (doesn't turn over) and the alarm goes off.
I scanned with Vagcom and there is a large amount of errors:
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 KG
Component: 1,9l R4 EDC 0400SG 5342
Coding: 00102
Shop #: WSC 06402
3 Faults Found:
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-00 - -
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0022017
Shop #: WSC 00001
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 922 E
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 04404
Shop #: WSC 00222
VSSZZZ1MZ5R085045 SEZ7Z0E3082693
1 Fault Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
No fault code found.
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 06402
7 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01331 - Door Control Module: Driver Side (J386)
49-10 - No Communications - Intermittent
01332 - Door Control Module: Passenger Side (J387)
01359 - Internal Central Locking Switch: Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
01333 - Door Control Module: Rear Left (J388)
01334 - Door Control Module: Rear Right (J398)
Coding: 00102
Shop #: WSC 06402
3 Faults Found:
P0321 - 35-00 - -
P1650 - 35-00 - -
P1649 - 35-00 - -
Readiness: N/A
Coding: 0022017
Shop #: WSC 00001
1 Fault Found:
Controller:
Coding: 04404
Shop #: WSC 00222
1 Fault Found:
Coding: 00006
Shop #: WSC 06402
Coding: 00258
Shop #: WSC 06402
7 Faults Found:
