guys i`ve tried to do the reverse passenger mirror thing and it didnt work , how ever now the window wont open or close fully , each press will only open/close the window for a little bit , it takes like 10 presses to open or close the window.
I`ve tried to change the settings back but without much luck , i might have chosen some thing wrong in the drop down menu as it was my first time.
Can any one help ?
Leon FR 1.8T 2014 (06) thanks !
Can any one help ?
Try resetting the one shot window.
Push the down button - keep it pressed for 5 secs after the window is fully down
Pull the up button - keep it pulled for 5 secs after the window is up
that should have reset the window.
Heh, do not know. Colleague gave me an USB cable which I plug in to the car socket under the steering wheel (LHD), with VCDS 11.11.2 on CD.
He performed update of his Audi Q5, which is older as my Leon MY2015 so it works for him.
Mine 11.11.2 ended withprevious mentioned error message and new version require update of HEX firmware.
But I do not know what is HEX firmware?!?? Is it in the socket of car? Can I update it?
No - it is built in to the genuine cables.
I think the only way to upgrade the hex firmware is to change cables.
I did not attemp to update HEX firmware, because I do not want to make any mistake.
But it asked me if I want to update it.
What is HEX firmware??
Can I launch update process or..?
I am not sure.
I have an official cable that gets updated automatically and free.
What I understand under "HEX Firmware" is firmware in electronics in the cable (hidden in end-plug).
Am I right?
I tried to update it as it was offered, but error message appears: Unable to Update...
I need to find VCDS version which already knows Leon ST 5F and is working with HEX firmware 1.92.
Any experience, advise which version VCDS???
that didnt help.
Any idea`s?
Great subject following
Any one has an idea about changing xds level? Is there any bad effect ?
I'm used to a mk7 golf and how whenever I came to any complete stop it would apply the brakes until such times as I engage the clutch to move off again where it would release the break... Is it possible to amend the leon to do this via VCDS or is it just a factor of the e-brake on the golf?
pretty sure that its only an E brake feature!
Anyone know the codes to enable auto light wipers, i've got the switch and sensor
Sent from my HTC One_M8 using Tapatalk
