hitandamiss
32
Belfast
Hi Guys,
I know the headlight condensation is a common problem but it's really annoying me on my 07 Leon FR. Anyone been able to resolve this problem? Only solution I could find online was to use an air pencil and air compressor of which I have neither so wonder if there's another solution or even has anyone had this fixed at a garage and how much did it run them?
take the rear cover off.
use a hair dryer to dry out,
then important bit, turn dryer to cold setting and continue to blow through for a good 5 mins afterwards.
replace cover.
another option is to increase air circulation in the headlight so installing vents/holes in rear cover is an option but need to do this in a manner so it doesnt easily allow water in.
Gave the hair dryer a go there and made NI difference after removing the light cover, maybe have to take the headlights out for it. I think the silica gel would help prevent it once it's cleared but without putting them in the actual headlight don't think they'd pick up the moisture. Nightmare
Easiest think is to take the backs off and take the car for a 10 minute drive with the headlights on (make sure it's not raining though!) then put the covers back on. This dries out any condensation in the headlights and the airflow from driving gets any condensation out.
you have condensation in a headlight, and blowing hot air with a hair dryer did not clear it...?
unusual..........
unusual..........
Yeah tried the hairdryer and made no difference whatsoever.
Keen to try this Rob but i'm in Belfast and it's December so might be a while before the rain goes off lol
I did this the other day, took it for a blast down the motorway, worked a treat :funk:
Took the backs off tonight, been out about an hour and no change to them fs
I did this on my Toledo at the weekend. Worked an absolute treat but, not only did I take all the covers off the back of the headlights I also had to remove one of the Bulbs (the main beam in my case) to create a hole into the headlight casing. Just removing the covers and not a bulb wouldn't have left hardly an space for the warm air to get into it.
I found taking backs off and have dipped and full beam on helped but it's not a permanent fix condensation creeps back after a period of time especially with our weather lol
part of this fix is to heat up the air in the headlight (by having the headlights on) which leads to condensation reduction as the water evaporates/is obsorbed by the warmer air.
this is fine - but only until the air in the headlight and the headlight lense falls below a temperature where the air once again reaches its dew point leading to condensation.
The second part of your fix is to remove the backs, - the idea behind this is to get air circulation, or to replace the air in the headlight. which is needed to avoid the condensation returned as above.
If the rear is removed, but headlight bulbs are still in place then the air circulation wont be great, perhaps in your case you need to do it again but make sure the air in circulated/replaced more thoroughly.
I have tried it also with airlines and bulbs removed also with hair dryer come to conclusion I have a dodgy seal on the headlight I read on here power washing doesn't help it much either lol
