What year / model did you fit them to ? As your profile says you don't drive anything ?
Also stu_m in his post has quoted a more expensive price for the struts, this is from the same German supplier as in your post, I wonder if they might be a different model, as I'd like to make sure first before I place an order.
Sorry for late reply, I just picked my brand new FR :) so I need to update my info here.
but anyways, I bought 2 pairs of them ones in the link and here is the results:
https://youtu.be/joDjeTZGl-E
I bought this set:
http://www.ebay.co.uk/itm/121816436948?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
you can expect something like this after changing the original ones with new ones:
https://www.youtube.com/watch?v=I3GNd9FefPY
I went ahead and ordered a pair of these. The one one on the right fits fine, but the one on the left doesn't fit as it is the same on the right. I fit the bottom part of the strut fine but the top hole is on the opposite side of the bolt. Am I missing something? The 2 struts ordered are exactly the same... would have thought I needed the opposite strut for the left side... !???
Ordered a set from the seller which Alakiha had linked to in post #15 in this thread.
Order placed Tuesday and arrived Friday, and fitted them today - WOW what a difference, perfect, they do exactly what I wanted, unlock using the key fob and boot fully opens, can be very useful at
Total price inc delivery was £25.64p
Is yours a 3 or 5 door, or do they use the same size strut?
terryt - Mines a 5 door.
Personally I would have thought that there's no difference between the 3 or 5 door models.
Happy to be helpful :)
Exactly its really easy and cheap tweak to do, I wonder why Seat didn't do it from the beginning!
Could someone please just give me a very brief run through with what to-do when changing the struts? I have mine sitting at home and ready for fitting when I get back from work.
I have a pretty good idea but would rather not break anything.
Angelos - this youtube video shows you what you need to do
https://www.youtube.com/watch?v=GjBqgR9HS-U
Takes about 5/10 mins, only thing you need is a small tipped flat headed screwdriver to prise the retaining spring-clips out - the existing boot-struts need a good tug to free them. Then when fitting new ones a sharp bang with your hand to locate them over the retaining pin.
Press and hold the boot unlock on the fob and it pops it open
Mine doesn't work like this, its held on the catch til you lift the handle (MY16 1.8FR). Do all need 'full release' enabling via VCDS or do some models/years come like that as std?
Think from an earlier post you just hold the boot release button on the key fob and it'll pop up. Like holding unlock to drop windows.
I think...
Could I do this on the st tailgate?
