N80 Purge Valve location?
dm222
1,488
49
replaced mine today, let's see what happens :)
it will rain this week but I'm anxious to test it when the sun returns :)
dm222
1,488
49
Yes! it's solved, two days above 20ºc all day at the sun and it started perfecly :)
SK-1987
11
BUMP!
Is this an easy job to do? First time doing any work on an engine - so glad to have found a solution. Been chasing this problem every summer.
Crank sensors, fuel filters changed + no fault codes is so annoying.
dm222
1,488
49
not that dificult, the dificulty is that you cannot see what you are doing.
removing the conector you have push the "clamp" (for the lack of a better term) for it to come off and it will come off easilly.
also the tubes turn them sideways first before pushing to make them easy to remove.
SK-1987
11
Right, i cannot seem to locate where it is. Any help would be great, thanks.
SK-1987
11
I can confirm that this worked!! Last week no starting issues in the heat.
Part ordered : Bosch 0280142345 Bleeder Valve
Took only 15 mins start to finish to fit. Took out the air box for easier access. Very easy job to do! Thanks for the help guys.
dm222
1,488
49
Nice I never had problems with this again.
Before I had the problem every day in the summer....
As a consequence damaged two starter motors and I think two steering pumps because of it could be related to it also since they damaged while trying to start the car multiple times.
thomas hunt
Yeap, it`s behind the air filter case. I cannot post a picture as I don`t have yet 15 posts.
Hope this helps.
Thanks for the part number.
Hi there I'm.a newbie cam someone post a picture of where the purge valve is located on a 2001 model seat ibiza 1.4 MPI please as I have a evac fault thanks Tom
RUM4MO
8,107
1,120
South Scotland
One thing to remember wrt dm222's reply, your car is a 6K Ibiza with a 1.4 8V petrol engine, this section of this forum is for 6J Ibiza and dm222 runs a 1.4 16V petrol engine, so the location of your EVAP solenoid might be completely different.
Edit:- you should ask this question in the MK3, ie 6K2 section.
Reactions: dm222
Aug 19, 2019
Hi all,
I have a 58 plate 1.4 Ibiza, and also suffering from the car not starting when warm issue, so looking to replace this N80 valve.
Could someone please confirm which is the correct part number, as I think two have been mentioned in this thread:
0280142345
0280142431
Many thanks,
Duane.
dm222
1,488
49
Hi all,
0280142345
0280142431
Many thanks,
Duane.
0280142345
