Which PC5 aerial booster do I need?
masterfrodo
266
8
Googling it, it seems there is the PC5-52, PC5-91, PC5-137, and others
I bought a fascia kit, including a booster from ebay as I wanted to change the head unit. Having fitted the supplied booster I don't think its doing anything. I tapped into the blue/white wire on the loom which from all accounts is the correct thing to do - power antenna/power amplifier.
So am thinking maybe its the wrong booster? Or should I tap into another wire, maybe the yellow switched power supply?
Gaz20VT
122
15
Interested in the answer to this too - I'm about to do the same thing.
As far as I understand it, you need to connect the aerial amplifier to the blue wire coming from the head unit, not from the car loom. Unless someone else can clarify?
747_727
1,113
Essex
Yes you tap into the blue wire which powers it.
Why do you think it's not working? Mine helped me pick up lots more stations.
masterfrodo
266
8
It loses signal where it didn't with the original head unit - thats why I don't think its working properly.
If the two looms are connected there is no reason why not to connect into the blue/white head unit wiring as it connects directly to the car loom blue wiring
masterfrodo
266
8
OK, getting bored of this now. I have tried a couple of boosters, and am still suffering with bad radio signal strength. I understand that the stock aerial has a booster at the base of the unit, but short of running a live wire through the cabin and up to the stock booster what are my options?
Leondave
21
Change the aerial to a non seat aerial. Im planning on doing this to mine when i get around to it. Someone sugested a vw polo one
