leestudd35
9
No longer working on my 2003 1.6s. Motor is still working, any ideas how I can unblock it? It was working perfectly fine, no gradual change at all.
Lee, it's most likely the water pipe popped off under the rear left boot cover - do a search and it's an easy fix - is your boot carpet damp at the left side??
Mines the same if you find a thread can you post it please
Sorry I 'm new to this still trying to work it all out on here
No probs, if you tap the SEARCH it opens a small drop down box, tap on ADVANCED SEARCH then fill in what your looking for (rear washer jet) into top left box. Now in the bottom right box open and scroll don to Leon MK1 then tap SEARCH tab bottom centre.
Treat this as your inf hub as there is a vast knowledge in there :D
Thanks for your help, found one and just sorted mine out
Thank you, sorry for the late reply! It is a bit damp so will have to have a look. I've also noticed the rear screen demister not working either. The button lights up, is it likely to be something simple like a dodgy fuse?
Finally fixed mine today also after a good few years! lol
On mine the pipe at the front had come off ...so we clipped back together and the rear washer started to work.
Except when I went to put all the tools away into the boot I could smell screenwash.
So then took the left side panels off and then saw the puddle!!
So another join in the pipe was also unclipped which is behind the seat belt.
