The Golf R Estate uses a different exhaust to the three and five door Golf R. It's actually the same one as the Cupra ST. Only the outer tip on a Golf R Estate's exhaust is actually an exhaust, it matches up with the line of the Cupra's single exhaust tip. The inner tip is just for show. The exhaust on the 290 SC/5 door is just an adaption of this exhaust. It'd cost more to give the SC/5 door the equivalent Golf R exhaust, whilst the ST & R Estate only have a cosmetic difference at the exhaust tip. So I'd guess it's doubtful there will be an exhaust borrowed or developed?
What is the actual difference between the sc/5 door exhaust and the ST's?
The differences are as follows exhaust wise:
280SC/5 door have a three silencer setup (the exhaust gas passes through there silencers before leaving the exhaust).
The 280 ST has a two silencer setup, with a marginally diameter wider pipe.
The 290 ST has precisely the same exhaust as the 280 ST.
The 290SC/5door have the same exhaust as the ST, only modified to be marginally shorter. Other than that, no differences.
The wider diameter two silencer setup exhaust is more free flowing, enabling higher boost at lower revs. The map in the cars with he 2 silencer system is identical to the map in the Golf R. This is why there is a nicer torque curve for the 280 ST & the 290 (although claimed as something new for the 290, it was the reason the heavier ST could do the ring nominally faster than the SC, without removing air-con etc.). The peak boost pressure is the same for all 280s & 290s, yielding in approximately the same peak power.
People keep saying the map didn't change. It did. I have quoted a source for this before on here somewhere.
The SC/5 door exhaust is not the same as the ST even for the 290's.
The 280 SC/5 door has 3 boxes (1 resonator and 2 mufflers?) running in series. The final silencer had 2 exits so that you have the 2 tail pipes like this:
The 290 SC/5 door only has 2 boxes as has the middle muffler removed. The final muffler looks exactly the same as above on the 280 (although internals maybe different I don't know)
The ST's (280 and 290) however have 1 resonator, then the exhaust splits in 2 (to go either side of the spare wheel well) and there is a completely separate muffler for each exhaust tip:
Maybe I am just slow...but to mirror the setup of the SC/5 door (with the only difference being one big muffler vs two small in the ST) one would need to remove the resonator?
Sorry for the terrible drawing just couldn't be bothered finding the oem diagrams...
Thank you for that!
Thanks for this.
So is the louder SC placebo?
Maybe the SC is louder because you sit CLOSER TO END OF THE EXHAUST where the SOUND basically comes out from?
How is the sound difference OUTSIDE the cars? I am happy with the volume inside the ST as it's a family hauler and not a track car 99.9% of the time.
