Very nice did you buy them I can't tell?
Tomasz looks good what turbo are you running? Stock internals? Lpfp?
Finishing touches.![]()
Nightmare! Hate people that do that! More than likely the camshaft solenoid mate, check block 93 on VCDS, the specified and actual should match, if they don't then unless the timing has jumped a tooth then its probably the solenoid. The other is probably a system too lean code which could be related.
Looking at selling the FR for a GT86
