I think nobody knows what is "Sensitivity" setting for?!
Here you are:
Why would you not have coming\leaving home lights on???
And as said the sensitivity is to set how light or dark it is for the lights to switch auto on or off.![]()
Well, three main reasons:Why would you not have coming\leaving home lights on???
No, I do not have high beam assist.I thought the sensitivity was for high beam assist.
But then if it's there and you don't have that option then maybe not.
3. I don't like the way how it works. When you switch off engine, your light goes off, DLR stays. Then when you lock, lights goes on again. ?!?? The same when entering car - after unlocking lights goes on, then off and finally stays DLR only or goes lights on again. It is a bit mess...![]()
+1. I would rather see where I'm going than worry about momentarily blinding the neighbours, because A. They shouldn't be so fkn nosey B. Curtains. Close them. C. I don't like them anyway. There is another, easier option. Park the other way round.Sod the neighbours, I love my car lighting up when I lock and unlock it!! lol
+1. I would rather see where I'm going than worry about momentarily blinding the neighbours, because A. They shouldn't be so fkn nosey B. Curtains. Close them. C. I don't like them anyway. There is another, easier option. Park the other way round.and if that means you are pointing at another house, just alternate it. That way you can pi55 two lots off instead of just one...
Really? Even on manual transmission? Does it need any setting via car settings?BTW you can switch the DLR completely off as longest your handbrake will be on
