Ive just got a standard 1.6tdi Tech pack Leon :p
have slammed the brakes hard before nothing happened so was wanting it turned on as its a good feature to have
Ah right. You'd think this would be a generic safety thing enabled that they'd sell to NCAP for an additional​ point. :D
you'd think that, might have to try again (in a controlled state, not someone pulling out in front) in case i missed them coming on
far as i know the emergency brake flashing should be on. Not the emergency indicator flashing
That might be on already, will need to check when its dark
the app does say hazards flash though maybe the translation is wrong then?
hi
I need the code for US lights in only sport mode. It has anyone saved code for paste here?
thanks
Here's one for US parking lights. Not sure about the sport mode part though. This is off the obdeleven pro boards.
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
(9) 0 BLK light fitting VL B36-light function D 0 Select (turn signal front left)
Select Standlicht allgemein
(10) 0 BLK light fitting VL B36-dimming select CD 0
Value:30
(9) -Leuchte1BLK VRB20 light function D 1 Select (Indicator front right)
(10) -Leuchte1BLK VRB20-dimming CD 1
Value:30
(12) -Leuchte0BLK VL-B36 Lichfunktion E Select 0
Select Blinken links Dunkelphase
(15) -Leuchte0BLK VL B36 dimming Direction EF
Select Minimize
(12) -Leuchte1BLK VRB20 Light Function E 1
Select Blinken rechts Dunkelphase
(15) -Leuchte1BLK VRB20 dimming Direction EF
Select Minimize
Sent from my SM-T520 using Tapatalk
Just received my obdelven pro and so far very happy.
Mods so far on mine and my friends
Auto mode fan speed lights
Carbon in infotainment
One touch mirrors
Needle sweep
We tried to get this one working but to no success has anyone else tried?
Brake light also in the tail light (gate). (LED Drivers)
With this modification brake lights (For LED) is also lit in the headlights of the gate instead of only on the rear wings.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Leuchte27NSL RC6
4 - Sub - D 27 Lichtfunktion
5 - Change value to Brake light
6 - Sub - Dimming direction CD 27
7 - Change Value to Maximize
8 - Sub - Dimmwert CD 27
9 - Change value to 100
Any one able to tell me if its possible to store a lower position on the wing mirror when in reverse? when i lower it it also keeps a lowered position when its in a forward gear
When you have the mirror dip enabled and the mirror position set to L you customise it to the kurb view you want, when you pull off leaving it in L it should rise back up to normal(where you set it in 0) after you hit 10mph
Swap L for R if you're left hand drive, obviously
Cheers dude ill give this a go later
It's the other way around.
L - For left hand drive
R - For right hand drive.
Basically, it's the mirror that points to the kerb when driving on the correct side of the road.
So i completed quite a few codings which are all working great. The only one i couldn't do is the one click folding mirrors which should be easy.
When i access (09) electronics and then adaption, i don't see an option for 'Control Access 2' or 'funk modus spiel...'... What am i missing?
When i access (09) electronics and then adaption, i don't see an option for 'Control Access 2' or funk modus spiel...'... What am i missing?
try look for 'Access Contol 2'
and on new modules this function can be found here:
2 - Adaptation
3 - Select - Spiegelverstellung
4 - Sub - Funk Spiegelanklappung Modus
5 - Change value "Funk Spiegelanklappung Modus"
2 - Adaptation
Awesome, that worked and all is good. I didn't have 'access control 2' or anything but once i was in module 09 (electronics) i could find Spiegelverstellung and from there it was easy!
Thx
Hi all, im trying to cheap out here but my mate has an obd port reader that connects via wifi or bluetooth that he says he can loan me. Its not an obdeleven one so will it connect and work with my app. Failing that anyone fancy selling me there port reader when they're finished with their as i have 800 credits on the app and no way of using them thanks
Sent from my SM-G900F using Tapatalk
No, you need the proper adapter, otherwise we'd all be doing it!
Curious to know how you've amassed so many credits though, assuming it's legitimate.
Okay thanks i figured that just me being cheap. Yeah i just grinded on the 6 free credits daily
Possible functions for Leon FR
Greetings. I'm considering OBD11 and, before that I have a few questions.
I have Leon FR 2.0 tdi 150, without light and rain sensors and with black&white FIS. It is full LED.
I'm interested is it possible to activate the following:
  • Carbon FIS
  • Welcome (test) mod on FIS
  • Sport menu mode on entertaiment system
  • Leving home lights
Yes all above is possible
Just don't know what you exactly mean on this?
