Recirc valve/dump valve
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
No problem.
Going back to the word REVO...who used this word? you or the middle man? You see revo is copyright protected I believe. Even put into there code as much as they can so cannot be used
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Middle man
Sent from my SM-G955F using Tapatalk
sounds like he's selling generic maps and passing them of as REVO. Big question is do you trust him to return it to stock map because I'll bet he's going to want to do that before money changes hands.
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
So basically saying im fooked
Tell him you want you're money back and you will take it to be mapped somewhere else so removing the rubbish that's on there now and him not having to touch the car,
if not tell him trading standards and the tax man will be round soon I'm sure he will change his mind and just refund you.
Be mean, this guy could of broken you're engine, cost you thousands, made you're life a horrible story just like his boss has made many people feel...then you got to explain to the other half!!(wife)
mty12345
3,774
478
bristol
Go get that money ASAP.
+1
Only use a reputable garage that offers revo maps, or a custom mapper with a good rep.
Anyone 'mobile' is to be avoided like the plauge! They are mobile for a reason...... they don't want you to find them when your motor either goes bang or drives like a pile of ****.
Bam225
62
Okay cheers for your help hes coming monday to take map off car and give full refund
mty12345
3,774
478
bristol
Revo is fine and the probably the most widely used map. Just make sure you are using a proper authorised revo dealer. http://www.revotechnik.com/dealer-locator
If you only have an intake on the car, then you only need stage 1. Stage 2 is for cars with the proper supporting mods, i.e downpipe, front mounted intercooler etc etc
Alexis27
2,104
455
Manchester
Bit confused. Yes you will need a yellow spring in the Forge 007/008, not the green one, if you've had any remap.
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Spring is what it is...first give away of a bad mapper.
Anyone doing this for a living should be able to sort the problem before mapping the car...if he can't due to no part or customer has no cash for the part the mapper should stop until it's sorted whatever the issue maybe.
What I wanted to know is who did it, so following the link will cure you're confusion as to what I was warning the op about.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Ok thanks,tbh bit pissed off but thanks for the info really appreciate it,ive messaged the middle man and staight away he offers me refund
get it flashed back to std and find an "actual tuner" one with a dyno and experience of remapping themselves, not just installing someone elses' generic map.
Guess it was cheap which was the appeal?
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Some of these "mapper's" are doing finance on generic maps. £150/£320 I've seen about Cambridgeshire.
Bam225
62
Ive been on the revo website and looks good so im gonna go with them at leasf i know they are good,£349
Bam225
62
Revo i guess ,dont know of any others unless any of you guys could point me in the right direction,the guy that took the map off showed me a diagnostic reading saying about spring pressure or somthing ,so he was trying too say it was the spring,but gave me the money back no probs,but when i done a diagnostic check there was no faults??prob chatting it
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Regarding the springs. Yes there are different colours wich have a different ratings for different boost levels.
Depends on the map.
There are some good names mapping these engines.
Worth doing a bit of research before choosing.
Quite a few with race pedigree.
Take a look at Revo, AMD, Badger5, R Tech, PTorque and a few more others may want to add.
Prices are pretty competitive.
Have a butchers.
Sent from my iPad using Tapatalk Pro
