Sparkie
Angling Adict.
Sep 25, 2009
2,539
776
Middlesex
Hi. Now another code has popped up.
17956 Boost Pressure Control Valve Open.
Sounds like it shouldn't be.
Is this my Split r dump valve messing this up? Only been on a week?
Any help would be invaluable.
Sent from me!
Hi again mate.
It should say "open circuit" http://wiki.ross-tech.com/wiki/index.php/17956/P1548/005448
So either the N75's not plugged in, the wiring is broken, or the valve itself is faulty.
Cheers.
I did unplug what ever electrical connector is directly to the right of the dump valve to make it easier to fit it.
Then drove off forgetting to put it back in.
Drove like **** and pulled in looked and saw it was unplugged.
Plugged in car fine.
Might that be the case or is that nothing to do with it?
Sent from my iPad using Tapatalk Pro
Yes that's exactly the case mate, that's the N75 (or boost control valve). Delete the code and forget it, the quick drive with it unplugged would of triggered it. If it's plugged back in then there's n nothing to worry about.
Yes that's exactly the case mate. Delete the code and forget it, the quick drive with it unplugged would of triggered the code. If it's plugged back in then nothing to worry about.
Once again a quick chat with you and calm is restored.
Thanks for the insight buddy.
Much appreciated.
