Low compression in all cylinders 1.4tsi
Prydar
7
Lancaster, UK
My car went in the garage today (1.4TSI Twincharged) for a diagnosis, fix the reason my engine management light was on and a stage 1 Revo remap today.
The garage found that the reason was the previous garage who fit some new spark plugs due to misfires on my car didn't put a hose that connected to my air intake manifold back and it was throwing up a bunch of faults, the garage hooked the car up to the diagnostics machine once again and found that 75% of the faults were fixed but there was still some faults that were saying low compression across all cylinders, the garage then proceeded to test the compression on all cylinders and they were all showing 73 psi apart from one which was showing 71 psi. They decided to clean out the combustion chambers, change the oil and oil filter to try and get the compression back to a normal amount but I don't know the results yet.
If anyone has had this problem or is experienced with this stuff would you be able to tell me what the chances are of getting normal compression from cleaning the internals and changing oil etc would be?
The garage carrying out the work is probably one of the most highly reputable garages in the NW that specialises on VW/AUDI group cars so I have no doubt their equipment is showing the correct readings etc, I'd just like to know what the possible outcomes this could have and if it's going to hurt my pocket a lot.
ADDITION: Car hadn't been serviced for 15k miles and also not serviced since the misfiring problem
Reactions: Crezzlin
RUM4MO
8,103
1,118
South Scotland
Sorry to be harsh, but why have you left this, known to be a fragile one, without proper servicing? This sounds a bit like valve trouble so it will be off with its head!
camelspyyder
2 SEAT-er
Jun 26, 2014
1,307
176
I have never been on any other car website with so many "I turned up the boost and now its f**k*d" posts.
Jesus, why not buy something that has a lot of power in stock form?
Prydar
7
Lancaster, UK
I see where you’re coming from here and I agree I shouldn’t have left it, I’ve mainly been doing motorway miles up until now and when driving the car the problems don’t seem to change the driving conditions of it so yeah I did neglect it because I didn’t realise how bad it was. It’s definitelt taught me and I won’t be doing it again.
Have also been really struggling with time also so it’s been hard to get the car booked in etc
Prydar
7
Lancaster, UK
Why not actually learn about something before you comment on it? I haven’t touched the boost, compression in an engine cylinder is supposed to be between 100psi and 150psi stock
camelspyyder
2 SEAT-er
Jun 26, 2014
1,307
176
Sorry mate, I wrongly assumed your post about revo stage 1 meant you were tuning.
R3k1355
1,872
275
Yorkshire
Remote at best, and to be fair they should probably do a leak down test before anything to try and identify where the issue is.
Were they specific in what they were going to do?
