Working perfectly now
Thanks for the help
No worries, when you close it either use both hands above the brake lights or if you're using the hand grip inside the boot it'll close if you pull it with enough welly. Takes some getting used to but don't do what I did and close it one handed in the middle as you'll end up with a palm print dent :)
Fitted today.
They had to go upside down because of the way the angled notch is on the opposite end to the originals, but they're working a treat!
Fitted today.
Sorry I meant to add about possibly having to fit them other way up, depending on how the ends were fitted. Doesn't seem to cause a problem though.
I had read it somewhere and was scratching my head wondering why...but as soon as I put them up next to each other the notch was obvious and I worked it out!
Doesn't seem to cause me any issues either.
Cheers dude!:D
Cheers dude!:D
No problem, just don't forget about them or you risk a smack in the face ...:D
when removing both sides you will be able to lift higher and the new strut will fit.
I just had a pair of these struts turn up today and after struggling for about 20 minutes thought I had the wrong ones......Then I read this post and it took about 2 minutes to fit both!!!
Thank You!!!
