OBDeleven modifications
Deleted member 103408
From the Golf Manual
Traffic sign recognition texts
Cause and solution
No traffic signs detected The system is in the initialisation phase.
OR: the camera has not detected any regulatory or warning signs.
Error: traffic sign recognition System fault.
Go to a qualified workshop and have the system checked.
Traffic sign recognition: clean the windscreen! The area of the windscreen in the vicinity of the camera is dirty.
Clean the windscreen.
Traffic sign recognition: currently restricted. No data transmission from the navigation unit.
Check if valid map data is loaded on the navigation unit.
OR: the vehicle is located in an area that is not covered by the map stored on the navigation unit.
No data available Traffic sign recognition is not supported in the country in which you are currently travelling.
Sounds like your error is not the same as mine (and other MIB1 Units) where the warning message appears after a fixed time regardless of where you are or what route you have taken. Are you maps up to date and does the navi system show the speed limit at the same point.
Reactions: Jaco2k
Re Digital Dashboard
Just seen this post on the OBD11 forum under the Golf Stream, to display album artwork and radio station logo.
Dashboard_Display_Configuration:
coverart:
On
stationart:
On
Does the Leon digital dash currently show this automatically or do you have to code it.
Anybody with digital dashboard, does the car come with needle sweep turned on.
If not has anybody tried
Control unit 17 (dash),
long coding,
byte 1 change bit 0
It works on the Golf, just want confirmation it works on Leon.
I am also told the app does not work for digital dashboard.
Ta.
Simple answer is it does not work on all cars, it is very much dependent on which sensor you have on your car.
Never tried it personally but i have seen lots of threads on Leon and Golf threads with the same issue.
The common problems if you have everything on your car that is required (by which I mean the correct sensor, not just a sensor)
1/ Some say this only works if the wiper stalk is in Auto, others it works in any if you have the correct sensor
2/ Some say you have to do a factory reset for the closing system (Car Settings Menu at the bottom of list is Factory Resets)
Reactions: Baron
Quick note on how to do a throttle body adaption
Thanks to Don (DV52) on the OBDEleven forum
Go Control unit 1 engine
Select Basic Settings
Select Test of throttle valve adaptation
leonisis
Quick enough for me....
Mar 21, 2016
256
66
Bangor NI
I've asked this before and still haven't been able to get it to work.
Anyone know why the mirrors on a 2013 Leon SC will only unfold with ignition on and not on unlock with the remote?
I would coded them to fold via remote but they only unfold when ignition is turned on. I've had a nose around using OBD Eleven but can't see anything obvious that controls it.
I know the later cars do this automatically when coded to fold with remote but not so with mine.
Anyone got any suggestions?? Any help greatly appreciated
Sent from my Pixel XL using Tapatalk
have you tried this
Folding mirrors with a touch control
With this mod, mirrors will fold without having to be continually pressing the button on the remote.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Control Access 2
4 - Sub - Funk modus spiegelaklappung
5 - Change value By command via remote control look key
and if you have and it did not work have you tried doing a factory reset (Car Menu, Settings, go to bottom of the list.)
Reactions: Glarh
Can you open and close them if you hold the button for a long time.
Last question what options do you have on your mirror button like the one in the picture.
leonisis
Mar 21, 2016
256
66
Bangor NI
Same button as that. Mine will only unfold when ignition is turned on. Before coding they folded on a long press of remote. Now fold on first press.
OK Can you pm me a copy of your BCM (Control unit 09) I have a look and see if I can see anything obvious.
Cupralevel
How to get more brightness to the roof spotlights. If i use mib(car settings/lights) dashboard is too bright.
I just want to change the brightness of the spotlights of the roof.
Damo H
4,707
2,817
Car Length In Front
Will do. It'll be tomorrow if that's ok. Thanks for the help
I’d prefer mine to only unfold on ignition, it what my Mk2 used to do. The number of times I have to get something out the car and not drive it, means the mirrors are folding and unfolding more than they’d need to.
Reactions: Glarh and Walone
Deleted member 98136
Has anyone had a go at making the DRL dim on the side you are indicating ? - just like an Audi does, Thank you.
