Notchy 1st gear
Dillon Lawrence
31
Liking the car so far (FR 115 TSI), but has anyone noticed it being reluctant to go into 1st?
Seems to take 2-3 attempts sometimes and it feels like something is blocking it going in. I've had it partially engage and bounce out of gear when setting off too so I always make sure it's in.
georgee
Ibiza 115 TSI with 1700km here. I have the same observations, it's sometimes hard to shift to 1st but you kinda feel once it's "there". Will it smooth out with time?
Dillon Lawrence
31
Yes, after 2-3 attempts it goes in and feels like it's gone into gear properly (smooth).
I hope it does smooth out but I might mention it.
georgee
Absolutely the same experience! Usually I force it a bit to "bite" from first try, hope that doesn't damage anything. :headhurt:Other gears are totally fine.
Pew.
1,451
142
Scotland
Also noticeable on 6speed 1.8tsi, reverse too
Usually when cold, fine when it starts to warm up
georgee
I believe it might have something to do with auto start/stop so when the engine fires up after being off for a while 1st is hard to engage. It happens with engine always running though.
camelspyyder
2 SEAT-er
Jun 26, 2014
1,305
175
Mine is notchy getting 4th - it baulks fairly often. Gearshift adjustment is clearly required but I can't be arsed taking it to the dealer till service time.
Dillon Lawrence
31
Anything under around 6-7mph in 2nd causes it to stall I've found. Going into 1st while moving is usually nice and smooth
It's 1st and reverse that seem to have issues.
Today I tried putting into 1st which as usual took a couple of attempts (60% of the time I'd say until it warms up). After it went in I took it in and out of 1st repeatedly from 2nd, 3rd etc. with zero issues (clutch disengaged whole time).
Restarted the engine, selected 1st and suddenly it's notchy again.
If it doesn't improve I'll mention it.
Cerfwo
33
I would bring it up if half the time you can't get the gear in. My FR 115 is fine in all gears. Every now and again it refuses to "go in" to a gear but I just put that down to me pushing it at the wrong angle. Doesn't happen nearly often enough to be an issue.
