Morning all, I was wondering if anyone could give me some advice and a link on some hub centric wheel spacers for a 2017 st 300, what mm should I put on the front and what I should put on the back wheels. Obviously I would also need to purchase longer wheel bolts etc. Also the car has had a stage 1 remap and I was thinking about getting the revo carbon series intake system, does anyone know if this is a loud induction or only on hard acceleration. Many thanks.
Hey, i have some Ecs Tuning wheel spacers on my cupra and i've never felt a difference in ride quality or comfort.
Here is the link: https://www.ecstuning.com/b-ecs-parts/gti-flush-kit-black-bolts/flushkt/
Cheers for the link carbajal, I didn’t want them for ride quality I just want them for the stance of the car really to push the alloys out. I take it you put the 15mm on the front and the 20mm on the back, you got any pictures of them on your ride. They will be going on a st 300.
Reactions: Carbajal
Of course!
Reactions: Deano j1971
Carbajal.... sweet ride you got there, just for some info.. what size spacers did you put on the front and back please..
Yeah will do... funny thing is got back from a two week holiday in mexico a couple of weeks ago, stayed in a place called peurto vallerata, one of the best holidays I’ve had fantastic place and people.
Awesome!
i live about 3 and a half hours away from there. I live in Guadalajara!
cheers
Be careful if you lower the car.... I have 11mm on mine f&b and both fronts caught the lip of the front wings, and a tab got stuck and shredded the front tyre...
wheres the carbon wing from dude? love it!
I'll make a proper post about it but i haven't had the time.
With quality pictures and etc..
But it's from Leap Works. Look them up on instagram as leap works and on facebook as LEAP. Tell them CarbaCars sent you!
Just for my info (as I am messing around with ride hight at the moment, what did you do to stop them catching the lip.
Check out https://www.willtheyfit.com/index.p...2=35&wheel_size=19&wheel_width=8-5&offset2=45, if i have your current setup correct then it shows
Compared to your existing wheel, this new wheel will have an inner rim which is 1.3mm closer to the suspension strut. The outer rim will poke out 11.4mm more than before.
Based on ukoldschool if you are going to lower that will cause you problems, not sure how wide you can go with Stock ride hight.
Reactions: gof
You guessed correctly for the current setup.
On the stock wheels I ran 11mm spacers in front and 15mm in back with eibach pro kit.
So I’m guessing 11mm all around would be okay if I’m understanding this the right way.
It did rub occasionally on the back but when i swithed to 11mm it was fine.
What is also bothering me do I need to look for specific wheels for the performance pack or pretty much all in the similar spec to stock will fit.
Also thank you for the link above and your effort!
You are very welcome re links, saved me a very expensive error when somebody shared it with me.
Afraid I don't know about the performance pack so cant answer that question hopefully somebody else can
Reactions: gof
