Does this look right to you guys? Remember it is LHD...
Can anyone post a comparable pic of their cars?
Does this help?
https://forums.seatcupra.net/index.php?threads/led-hightlights.409802/page-7
Oh just realised yours is FL Mk3...not sure if same pattern then...plus is it not easier to see shone to a white wall?
Right side needs to come up or left needs to go down.I have another video - view, but would need to edit the plate out.
At a distance, the driver side is a fair bit higher than passenger side.
They just gave me the car back and I guess did nothing, since I was told "it is within the tolerance".
Well, I guess I will need to fix it myself
...the guy from the desk confirmed that there should be a ladder patrern, with the driver side being lower than passenger. Right now, it is not like that at all...
---edit--
Found the pic from a distance, once again, I remind this is a LHD car:
"Within tolerance" my ass...
Oh yeah that's horrible! That can't be right. I've seen mention of altering the height on the pre-facelift models. Not sure if the updated ones are the same but I am sure someone will be able to advise.
Easy enough to do yourself with an allen key
BUT - they don't even look in line with the car.
IIRC from my days of owning a projector headlight car with retro HIDs. The beam pattern would be higher on passenger side to show side of road further.
Do they auto level when turned on?
Sent from my SM-A520F using Tapatalk
Yeah, I think even the horizontal alignment is off... Bunch of clowns.
I need to get the correct way to measure so that o can align it myself without depending on these clowns...
As you have access to VCDS/OBD11 Have you tried doing the basic settings process under control unit 55
You assume far more than we would give them credit for in the UKNot yet, but I would assume they are not THAT stupid
