What small modifications have you added to your Leon?
AdamC11
191
Bolton
mk1 cupra splitter
changed fr start up to cupra
carbon radio and dash. needle staging
glove box holder
Load liner and net painted the front bumper black and polished the back out of it
black mirrors and vinyl roof lock command mirror fold
Golf R key because I thought it looked a bit like fr ha
Hi,
Where did you get the little holder bit in the glovebox from?
EFF11
138
38
12v Socket Bung
When I lost my bung I replaced it with a 12v plug with two USB sockets. Tons of them on ebay.
generationgav
64
I've got one of these that I stopped using on my Mk2 in place of a powerful one and I didn't leave either in permanently anyway. But this makes sense and I'll have to dig it out!
Ash82
148
37
Manchester
Hi
I’m new to the forum, mods I’ve done -
Added auto lights and wipers
Welcome and come home lights on
Needle sweep
One close wing mirrors
LED reverse bulb
Full led interior lights and boot
Painted brake callipers blue
To do-
Add led fog lights and then turn on Corning function
Deleted member 103408
Welcome to the site @Ash82, what are you using to make your changes (Carista, OBD11, VCDS)
Wastedagen
478
101
Milton keynes
Hi
Needle sweep
LED reverse bulb
To do-
Welcome and liking the mods... I also upted my cornering lights (LED H11 from stock H8(straight swap, same fitting)) to work upto 40mph instead of the default 20mph.
And enable Fogs to flash at same time as high beam...
How did you add auto wipers?
Reactions: Ash82
Ash82
148
37
Manchester
I
I have got the FR model , doing some searching on the forum found the sensor and it just plugged in behind your rear view mirror.
You have to program auto lights using vcds. Luckily I’ve got the programme
Reactions: Wastedagen
Ash82
148
37
Manchester
Thanks wastedagen, I forgot to add I’ve changed the jet washers to the v spray ones and added the crome bit on my key fob
Best small modification's
1/ OBD11 - if you dont know what it is or does check out the thread
2/ Installing Bonnet lifters - car should come with this as stock.
