I thought have a laugh and ordered these LED HB4 bulbs from Wish.com for £10 inc postage for the front fogs. The listing is for one bulb not two.
https://www.wish.com/product/5b890f247cd0306b0105be4d
I'm amazed that they are just fine and I don't get a check bulb warning :funk::bounce:
Original
Wish.com bulb
Comparison
Just looked it was £10 in total as the post on wish is for a single bulb but i'm amazed as it said canbus ready but I took that with a tub of salt lol
Them fogs look like they have a big butt... Do they fit in the housing ok as the standard ones have a 90 degree angle on them... Or is that link showing me the wrong pic? I haven't signed up so not sure what's behind it lol
Yeah plenty of room behind the only tight bit was the front of the heat-sink presses on the plastic when twisting into the holder but pushed the bulb with a screwdriver on the bulb tabs and in they went just fine [B)]
Here is where it touches when screwing in at the top of the angled bit of the heatsink.
I wish i was joking but no im not :beer:. I was sceptical at the 100000LM claim as we know that isn't going to be true but I will test again when leaving work but tried on off several times and never got an error. Spelling in the pictures is terrible but i didn't care about that not to order.
Got some plug fit decoder/resistors on order from amazon so will see how these go as well.
Which ones did you order? I got some that had gold resistor in the middle... They didn't fit our connectors so I got a refund... Now trying a new set which should be here today lol
I ordered these ones will see how they are should be with me Monday.
Loutsbe Car LED Headlight Canbus Error Free LED Decoder 9005(HB3)/9006(HB4) Plug & Play Computer Warning Canceller & Anti Flicker (Pack of 2) https://www.amazon.co.uk/dp/B077VKRXZ3/ref=cm_sw_r_cp_apa_4WmWBbXVKJ2SG
Removed the front number plate surround as decided it looked better without. What are people’s opinions on square number plates for the front?
Not a fan of the square look decent on jap cars but not so on others imo
I like square plates but have always thought it would block flow to the intercooler (if only slightly) i see people with mk5 golfs who mount the number plate on the lower grill and block the intercooler , think it's standerd on btcc bumpers mind you.
bagged fr , k1 rep , 19s
Car had a service and next to fit some new bits:-
Rev G recirc valve
Front PCV valve with new gasket
Variable valve timing solenoid
Fuel pump cam follower
Fog lights canbus error correction units
BKR7EIX Iridium spark plugs
Just a few bits then.
Rev G recirc valve
That looks like all the prep for a new map lol
