Mirror Dip / Assist Systems
Andy499
Hi!
I was wondering if the Leon FR Technology has lane assist? I see front assist on the driver display but not sure what it does, it’s just a grey box.
If it has Lane assist, how do I enable it?
Also how do I enable my mirrors to dip when I’m parking?
Thank you in advance!
Dearnie
143
Humberside
You will need to use the OBDeleven tool or VCDS to activate the mirror dip. Personally I used the OBDeleven to activate mirror dip on mine, couple of minutes and it was activated.
Walone
1,578
436
Near Heathrow
Mirror dip should not need activating with VCDS or OBDeleven, it should be selectable in the car menu setup and then you have to have the mirror switch set to L/H adjustment (assuming RHD) for it to work when you select reverse, it only works on passenger mirror.
Andy499
I’m sorry I’m not familiar with abrieviated terminology.
What is VCDS?
Why does it only work on passenger mirror?
Any info on lane assist?
Walone
1,578
436
Near Heathrow
What is VCDS?
VCDS (formerly known as VagCom) is a diagnostic and coding tool made by Ross Tech USA for VAG cars. The latest versions of which are the V2 and Hex-Net interfaces. Earlier versions are not suitable for cars after 2016.
It only works on the passenger side because that's how it's made by Seat, VW etc.
I think lane assist requires a camera in the front screen.
Dearnie
143
Humberside
What is VCDS?
VCDS is software from Ross-Tech bloody expensive and if you don’t know how to code, stick with OBDelevn much more user friendly.
With regards to the mirror dip it does work on both LH and RH side, however you can only select one or the other.
Can’t help with lane assist as I don’t have it.
Walone
1,578
436
Near Heathrow
I've never seen or heard of it working on the drivers mirror, unless it's something that can be enabled with coding.
xyz
565
204
oxford
Visit site
Only works on passenger side because it’s for assisting in parking next to a kerb. Should be selectable in the car settings.
rickster665
Rickster665
Mar 8, 2017
67
Rotherham
Mine will work then it wont any idea to why its been like this
rickster665
Rickster665
Mar 8, 2017
67
Rotherham
Lane assist is camera based far as i know but what about active criuse controll the radar is already there for front assist but to be honest its ****
rickster665
Rickster665
Mar 8, 2017
67
Rotherham
Does anyone know if the front assist radar is the same as the cruies controll one needed for acc ?
I would love to have acc
Is there any bits i may need extra if its possible to use the radar from front assist?
James_FRwagon
57
When I picked my fr estate up the mirror dip worked, now it doesnt seem to but I havent touched the settings. I just checked to see if it was still switched on and it was! Not sure why it stopped it was dead handy gaha
rickster665
Rickster665
Mar 8, 2017
67
Rotherham
Bang same soon as i picked it up it worked then it stoped a while after
rickster665
Rickster665
Mar 8, 2017
67
Rotherham
Im thinking maybe un ode and recode might fix it but im not technical
Walone
1,578
436
Near Heathrow
Have you moved the mirror switch away from the passenger adjustment position? Mirror dip only works while it is set to L/H (RHD cars) adjust position.
Reactions: Yamyam and Butty
James_FRwagon
57
I actually did yes I keep it in the center position! Will try that tomorrow!
R4CK5
609
85
That might be the issue then, mirror adjuster needs to be kept on the passenger side mirror for the dip function to work.
