What did you and your MK2 do today?
DanDiesel
In my diesel is where I'll be, chugging merrily.
Mar 17, 2005
168
10
Kent
Too true, Im surprised its taken to long to become such a common thing, I had an MG ZS 180 when they first came out and that was ahead of its time as it came with a can... which was useless when i needed it as the hole was quite big and the stuff didnt seal it. I was so happy! ha!
What tyres did you go for?
Brimfull
1,385
418
Wrexham
Tried to fit a rear wiper blade only to discover ecp had sold me one for a 2009 onwards so completely different to the 05-09 one that I needed
Legojon
I only wanted a remap
5,316
2,748
MOT passed today with no adviseries. :dance:
So yeah, let's not worry about the 6 warnings on the MFD for all the LED bulbs and the warning light on.
Hawkers
334
58
Norwich, UK
Changed my serpentine belt as there was some squealing going on and has done 80k miles.
Jimbobcook
6,176
2,561
ZiggyEP3
406
72
UK
Started to check which bit is causing the problem as the washer jets front and rear have stopped working :censored:
Looking like its the pump i guess, trying to check online how easy to change myself but not finding much to go on. I know the bottle is behind the drivers fog so will take it out to have a look.
Hawkers
334
58
Norwich, UK
This is how to remove reservoir but you get the idea.
Remove front right mudguard
Remove front right headlight
Reactions: Jimbobcook
JohnnyMackers
31
17
Not today but Sunday gave a good wash, clay and polish, used autogylm shampoo, super resin polish.. didn't take any pictures though apart from it raining yesterday and noticed the roof.
Quite a few swirl marks in paint which I'll sort out.
stephen
82
10
got some h7 led bulbs of ebay just to try them, brand nighteye or something
the passenger side went in fine and lined up great, drivers side, wont line up for some reason and i get the normal error message on the dash
but they seem nice and bright
need to get another look at the holder see what is happening
there is meant to be adjustment holes, but there is only one hole, so cant move it much
Legojon
5,316
2,748
Just to check. You put them in with the tag at the top I think it goes? Maybe taking a picture from the front would help so we can see it. Maybe it's catching on those little diffuser things.
Reactions: stephen
stephen
82
10
Il get a look on Saturday in daylight. I must had the second one in wrong. The first went in great no problems
Need to read the manual too see if the lights are meant to be vertical or horizontal
Order a canbus corrector thing too see if that gets rid of my warning
stephen
82
10
got the bulbs in today
the problem with the one bulbs that wouldn't go to the place meant too was the wee tags on the bulb itself
so a bit of electrical tape and that sorted it
not sure if i like them mind, the light if very close to the car, does it go far im used to philips racing vision and they seem to through the light more up the road
and with the need of the ebay 2X H7 LED Load Resistors 50W 6 Ohm Stop Car Light Flicker Cancel Error Message and thats just bulks everything up, cant put the rear cap on so its a mess with cable ties
but they are in and working, no error and not blinding anyone
ZiggyEP3
406
72
UK
Changed my recirc valve to be surprised to find my car had an 8 year old Revision D. Put a revision G on instead as its the better of the two types.
Im sure its not meant to but the old recirc came apart when lifting it out.
Reactions: Brimfull
