I have used OBD. I have activated, mirrors fold in 1 click. Beep on lock and unlock. Dial needle sweep, park assist to come on the screen when activate reverse.
How did you get the park assist to come on screen? I have no option for that in carista? Neither the reverse mirror dip...I have used OBD. I have activated, mirrors fold in 1 click. Beep on lock and unlock. Dial needle sweep, park assist to come on the screen when activate reverse.
I have struggled to find the mirror dip.
FYI I have the FR. I believe lower specs use the horn on lock and unlock which isn't great.
Sent from my SM-G965F using Tapatalk
Give this a goHow did you get the park assist to come on screen? I have no option for that in carista? Neither the reverse mirror dip...
What’s that on? My carista app looks nothing like that. Just options to enable/ disable things. If it’s not showing then I can’t do anything (like optical parking assist) unless it’s on the developers menu option? Or beta mode? Thanks for the reply!Give this a go![]()
That's how to enable it when using OBD11. They are the steps I followed to activate it.What’s that on? My carista app looks nothing like that. Just options to enable/ disable things. If it’s not showing then I can’t do anything (like optical parking assist) unless it’s on the developers menu option? Or beta mode? Thanks for the reply!
Does the needle Sweep work now in Carista? It didn't when I had it about a year ago.
Likewise. I've been trying to work out if it's because sometimes I turn the key too fast, or the parking sensors come on, or my phone is plugged in, or any other random thing, but I don't drive often enough to test it.Well coded for the needle sweep and sometimes it does it and other times it doesn't. weird
