Ibiza Coding
Deleted member 103408
Based on what i see on the OBD11 Forums and my personal experience with the Leon the needle sweep can be hit and miss and certainly if you turn ignition off and straight back on it normally does not work.
I dont know but again from what i have seen the Digital dash does not have and cant have coded needle sweep on this software version.
ayrshiredude
208
23
Drom what I am seeng it only works occasionally. I've tried it getting into the car for the first time as well as taking the key out and back in again and still only does it ocasionally.
LR231998
Alor Blue 290 Cupra
Jan 21, 2019
485
188
Can confirm for me it works 80% of the time.
Reversing mirror dip doesn’t work at all even when set to “L”
I’ve got the park pilot working well.
I got the beta version from an email to carista and there’s a lot more nice options, most of which for me have worked :)
Bruno Maia
61
29
Lisbon, Portugal
Can you post a video of park pilot working?
Reactions: Jonathan Bassett
Aroza
10
Give this a go
Sent from my SM-G965F using Tapatalk
Hello there!
I have the OBD11 but when I connect it to my Arona the control unit does not show up.
Any ideas?
Bruno Maia
61
29
Lisbon, Portugal
Question to all you guys.
In the new platform, MQB seat cars ECU also bring the now famous TD1 flag.
This is a flag in the software that signals if something was changed in the ECU. Since coding is basically changing ECU parameters, do you guys know if using VCDS, Carista or ODB11 will trigger this flag, and consequently make us loose warrenty?
https://forums.vwvortex.com/showthread.php?5635710-TD1-warranty-flag
Jonathan Bassett
124
30
I didn’t know about this?! Hopefully someone can confirm
Aroza
10
Might sound obvious, but is it showing the correct trim that yours is?
What do you mean by "correct trim"?
The coding worked with other adaptations.
I just can't find the specific control unit 76 to enable the park pilot.
But I have aftermarket rear sensors, so I guess this is the reason why...
LR231998
Alor Blue 290 Cupra
Jan 21, 2019
485
188
If you’ve already used carista the damage will be done so no point worrying just prayer nothing happens! That’s what I’m doing. But saying that if the gearbox fails an audible beep coding isn’t going to cause that
at0ny
155
34
Holland
I have activated mirror dip in reverse with vcds. You can activate it in the car menu now, but it don't work. The mirror go down a very little but don't return in his original position. Useless.
On some cars with dsg it Works. But not all.. On manual it dont work. Code many ibiza 6F here with a lot op option. Last week 2 ibiza's both no mirror dip working.
Also using vcds with hex v2 unlimited licence.
Some options what is posible:
- needle sweep
- volume to replenishd
- blower status in auto mode
- folding mirrors with locking
- horn locking & unlocking comfirmation
- horn locking & unlocking comfirmation in car menu
- drl option in car menu
- fog lights on with reverse
- corner lights
- comfort closing Windows option in car menu
- carbon skin media system
- expanded diff lock from medium to strong
- off road menu
- driving school function
- laptimer
- Ignition warning off
- seatbelt warning off
https://www.facebook.com/Vagcomdordrecht/
https://www.instagram.com/vagcomdordrecht/
Verstuurd vanaf mijn SM-G965F met Tapatalk
Daniel Stubbs
9
Maybe with a swap activation but dont think its posible.
Supported codes
00040100
00050000
00060100
00060200
00060300
00060400
00060800
00060900
00060b00
00070200
00070400
0740000e
08400002
09400003
0c400003
Those are the codes that are supported for my car
Reactions: at0ny
