EGR removal
Paul Smith
216
19
My egr is blanked off but has anyone removed all traces. Pipes, sensors etc.... ? Is it possible and what was the result.
Paul Smith
216
19
Google begs to differ. If it's blocked off and passes the mot then surely removal of the whole system would be fine?
R3k1355
1,786
251
Yorkshire
Gotta check the MOT manual mate, can't trust the first thing that pops up on google.
8.2.2.1 Exhaust emission control equipment
You only need to check components that are visible and identifiable, such as diesel oxidation catalysts, diesel particulate filters, exhaust gas recirculation valves and selective catalytic reduction valves.
  1. Emission control equipment fitted by the manufacturer missing, obviously modified or obviously defective
Rusty2k
710
133
Right, but the sentence you've cut out of your quote between the sub-heading and the description of the check says:
This inspection is only for vehicles that must have a full catalyst emissions test (disregarding the basic emissions test). You only need to check components that are visible and identifiable, such as catalytic converters, oxygen sensors, and exhaust gas recirculation valves.
Last I checked diesel cars don't get the full catalyst emissions test.
https://www.mot-testing.service.gov...class3457/Section-8-Nuisance.html#section_8.2
Reactions: Paul Smith
R3k1355
1,786
251
Yorkshire
I've even put the correct header number in, at least bother to read down far enough.
8.2.2 Compression ignition engine emissions
If a diesel particulate filter has clearly been cut open and rewelded, you should reject it unless the vehicle presenter can show evidence that there was a valid reason to cut it open, such as for filter cleaning.
  2. An induction or exhaust leak that could affect emissions levels
  3. Evidence that the diesel particulate filter has been tampered with
Rusty2k
710
133
Honestly check the ******* manual will you??
Haha, fair enough… I clearly have read the wrong part of the manual so my apologies for that.
What’s with the swearing though…? Really...?
Paul Smith
216
19
I read this as only check parts that are visible and identifiable. If all the egr bits are removed then surely are no longer checked under the mot?
Rusty2k
710
133
Part of it will be down to what can / cannot be seen on a visual inspection and part of it will be down to how familiar the tester is with the particular vehicle / engine.
On my CR engine the EGR pipe is clearly visible with the engine cover on so if the tester knows it's supposed to be there and isn't then they should be failing that.
Don't forget there's a port on the exhaust manifold that will need blanking off with with the EGR circuit completely removed and there's no way to do that without it being obvious there's a blanking plate that's been put there. This would be visible from an inspection from below, as would the absence of the EGR cooler if you removed that too.
R3k1355
1,786
251
Yorkshire
No, like the manual says if it's obviously missing then it's a straight fail.
The MOT testers aren't idiots, they'll know what the EGR looks like and what an EGR delete pipe looks like.
It's front and centre on the engine too so it's completely obvious.
