cejsmith Full Member Mar 19, 2004 83 4 Milton keynes May 23, 2019 #1 just noticed that the dab selection on my new cupra has stopped being able to find stations. FM and AM work fine. Any ideas otherwise I’m of to the stealers.
BoomerBoom Active Member Jun 1, 2018 814 297 May 23, 2019 #2 Not to overlook the obvious, but have you tested another DAB radio where the car is located? My DAB drops out completely in places where I live, then doesn't always switch back from FM when the signal returns.
wolverine_uk Active Member Oct 18, 2018 69 6 May 23, 2019 #3 Maybe try a factory reset. As it will do a scan when booting back up. Sent from my SM-G965F using Tapatalk
cejsmith Full Member Mar 19, 2004 83 4 Milton keynes May 23, 2019 #5 How to I reboot it, I’ve turn it off and on?
wolverine_uk Active Member Oct 18, 2018 69 6 May 23, 2019 #6 It's in the settings. Can't remember where but think it's in the options towards the bottom. Sent from my SM-G965F using Tapatalk
Deleted member 103408 Guest May 23, 2019 #7 Car, Settings, you can do a full reset or just a reset of the related part.
cejsmith Full Member Mar 19, 2004 83 4 Milton keynes May 23, 2019 #8 theoldboy said: Car, Settings, you can do a full reset or just a reset of the related part. Click to expand... I had a quick look , but couldn’t see the option for media system. I don’t really wan to do a full factory reset
Deleted member 103408 Guest May 23, 2019 #9 I do full factory reset loads of time, as far as I am aware it just syncs various control units in the car. But if you are worried then take it to the dealer and let them do it .
cejsmith Full Member Mar 19, 2004 83 4 Milton keynes May 23, 2019 #10 theoldboy said: I do full factory reset loads of time, as far as I am aware it just syncs various control units in the car. But if you are worried then take it to the dealer and let them do it . Click to expand... Fair enough I’ll give it a go
black_sheep Active Member Mar 10, 2013 1,244 588 May 23, 2019 #11 You can reboot the infotainment unit by pressing and holding the power button for 30 seconds; release when the start up screen is visible.
cejsmith Full Member Mar 19, 2004 83 4 Milton keynes May 25, 2019 #12 I did the reset and dab started to work for 5 mins then stop again , think I will take it in to seat.
