Key sometimes will not turn in ignition barrrel
Dai_O
154
Cardiff
Hi Guys
So I got a 2007 Seat Altea XL 1.6 petrol
My issue is as it says in the title
Insert key into the ignition and it turns fine to position 1, accessories, ie radio etc all come on fine
yet trying to get to position 2, ie red lights on dash, internal fans etc I have a problem
The key will 90% of the time not go from position 1 to position 2, I can fiddle and twist and push and pull and it will go to position 2 and then on to stater motor engage and the car starts fine, took me 15mins last night to get it to turn from 1 to 2, the steering lock is not on, but still i try to wiggle the wheel about
Now here is the strange thing even with the key out fully the steering lock would not engage, i can turn the steering wheel full lock in both directions, yes it is heavy as engine is not running but I am sure it shouldn't let me do this
I have tried both of my keys but its the same with both.
Any ideas????
Cheers guys
Brimfull
1,385
418
Wrexham
Hi Guys
Any ideas????
Cheers guys
Faulty ignition barrel
Dai_O
154
Cardiff
wow brimfull thanks for the quick reply mate, can i just check, r u talking about the barrel itself ie the bit the key goes into, or r u talking about the metal assy that the key barrel goes into
Dai_O
154
Cardiff
So got myself back up an running tonight
so this is wot i have found / done
I managed to use a thin piece of wire to remove the key cylinder, once the cylinder was out it turned freely so ruled that out pretty much straight away, key moved freely from off to accessories to on to starter positions, also the key came out too
next thing was to look at the barrel housing
i will try to show wot i found on the attached photos
6czYQBntYJYpSGwCx39c0W233Dm4aC-SZUCgNcWgPJsDBYIaBAC2i1uI2lESpzcHxy9r-3Ntoxt7bMPzt2hcCgLk7oHU3FM6rBdWoFczXgkrWXdHtIgILYjpOCL_B601bTNe3VXP3e9hwuH5rvSIhJ7WJh9ShvuA9ZgejKyyrVeS0NCOLxvVo9J5vyYZT2Uy4yUbfNgorWD4rTnOSfxoUf3dRvWUjiUp7spETM65UPmfvuppSRZsjb4Bl03obDkkXtOoHKb3XftAN4QkHq6o-FWs8IlQXtbpjR4_cufYyzzFZ5UTZb32fM37TNqQePzoBw036PtP5DIdcEU45RfVeQYybYHbYXynnWCLsWATuk1LfQKXYVGMeUt4AOlNGNzy6x5ghlAjY52Q1hSdemmy3e__3ZQCk84L6xbX9EsexDXcgo2dx795zQAt8fREok-QVoW5KdPxjHW_6tTy_WtdXTaJgH3uKDTVGHDBg9O7U1_u_Y6__UnKHSkFgy-bNbBjSMiAxUAY7lHrZ4wz2VTYsQzIJtWYjAaiWrkCKBX0mARG9AuhJGkD6JQJOPEUJC7SLG8mImtv7Y1i6yqIfAvOlwQlBxbM61M4zjzZ48GzdH90Tk_6VaIWCnDOUldlj0kDOJNzkd9UZtGfnt94GS1WxFUt4IYTI1g=w493-h657-no
All looked fine here
removed the white plastic holding piece and a few metal rings, then found a small slither of metal
as you can see the bottom of the circle had snapped of and was lying on the bottom
V9xwU7WhuPSZrRDM26ai5C88E_oa1_4p0GHY28suXeCbz5Zf1Tth9lGusAwGQ75xk-G97eDXbxZYDdJjKyJDWkhZLssjvuO5XS4iLbYqwpZyZ_Vt3K8wjTHgJRjNCS-DwKqOk4fjHyYoXP566ZpzhupxLMYKCUamFf3dlZN7Z_gETU791-vjM3JnAVnezTR-E-SzgzeSZ1ErBvwaoNfSWmoQjyH0lfBmJxFCXAO-yXxmKyZmH65upZ3mKQLCueCS9IMoORUwX8s9CvR6kDoEqhsdiTOX-HWrouh13yHZHIFrhmMv-_E9QOvxC6_sY8576O-YC8ACkPo3PilE6d_aIrcbsU7ALH9B774ZqYvYHyZOx2nZP3-Or0LQPjr9TNZp4gv4XD-X4sAwSSM1maje6EJk5UCvEF1lYmMzwwEG1wlwSdycAwWUwKfzPztd7NQCV6cszorl8c_MkPhwPNhgXWDF9JRAW36n4qrQr94qVp_hvDz5VecvedT92Mys42zipLvV8s1Y6c5N4JTSAhh7qz6xTrbD2SpIAFpehYaCZc-VLJmwEtBq4Zz1nioobf9ynsSWpY2BdxIvqBneaIz2SeKm1yVh7n296pSfJxT-wuNf2rL7pdUSIGsAeHzWwy4YnF1dcqEbd4MtM0_sECkw0BhqEpRKBnw=w493-h657-no
So i removed the broken bit and the pin behind it and reassembled it
TyjO4vkGNivYA5mPadoHmtD3yjk_FQEN5r6yD7tgBOZIthJ9sFEwajq-Hjzue74ZZCAm4lNnMm4NxDWUgSU5Zh1SJnkE0DxYqa1gkC0iQNyf4hpPdQZAbH9Ieul_yqSyHwNBjKUk2OjaAjWbsQ0LHThvhgErRjt7tLp_loN0MEsHepuMoq8FTmBjqH0c3HATsbjbYFtv5wstoDqBwpveIVzgWmND4J7G6m71KTUPO5cUDSgkLc-IiuhDRhYzTWzDnpMI4PRcjO52UJOsmDTEYf3FtN3aUGdAK7tcMWeB59ANZQNUMLpgQ3KTYOchwIA2mpGAi0A9UcbI3Qzhq-FY99ovp1wlGvRPcVcJ_EvBKvZ5mphyEOaZkVJLIjHHPyPy1bs7-9Qn0SjADSWSp_Ol37B8U7B1PKC46Z6ryU4sPu8eXV7VjYCasMZWeaxEe0pxtFBZVqac7Bd8d8wgfzfBTX1M8T-yhlwVJEZVT1WZAccHTFR812MfPufhoGG23E7xHUFuylxfMYfPj5QEmw7MT6Eq3e4B1HOlac5RwkuqaX2EsF184FwhVjurZLa0h2NYzgk3ru00hcc4mM9eGEItOV6bxDY4VsEr2gR8_R3S76ifJLJSfl4aLihYBUUzsj2nq6unt-eJ4ayBirgKN63aOLiFukaSFOY=w493-h657-no
All seems good, not sure wot the purpose of the pin is but all seems to work okay
will give it a good test on the weekend, may even see if the pin will go back in
found this useful
will let you guys know the outcome
Reactions: MarkTDI and Paul61
Aug 5, 2024
What tool did you use to remove the steering wheel nut in the middle? Cant really track it down.
