Cold air intake.
Gargi
22
9
Is there anyone that has installed a cold air intake? Have you seen any gains? I have installed a custom air intake with custom made air box for heat shield and a simota cone filter but i think that the car is slower. Might be me! I can't tell for sure. Now i have the oem filter system back and i hope to feel the difference. I intend to do some test and measure the time. I have the 1.0 fr 115hp.
114
9
Most videos on youtube will show you that installing a cold air intake not gaining any additional horse power and its all a myth. Except giving you a sporty sound.
Gargi
22
9
With oem filter system back i i can't tell any difference. Only that the intake temperature is slightly better with my cold air intake. For instance with 30 degrees Celsius ambient i have 55 iat while with cai i have 50 to 52 degrees Celsius on the same driving conditions. I have take some timings with oem for instance 80-110 kph with 3rd gear and i want to put the cai back to see the difference. When i am ready i will post some numbers and photos.
Gargi
22
9
Hi guys. My CAI is on the car again. I will post photos and times soon. I am very satisfied. Car seems to be faster. I haven't finished the tests yet but from the little i have seen the car is slightly faster!
Gargi
22
9
Ok guys. My tests have been completed. Here are the results. All timing made with timer. No fancy gadgets. Only 80-120 is from torque application.
Oem intake Cold air intake
3rd gear
  • 80-110 kph 4.7 4.7
  • 50-80 kph 4.1 3.9
  • 80-120kph 6.7 6.5
  • 2000-4000rpm 6.8 6.5
  • 4000-6000rpm 10.1 10.1
  • 4th gear
  • 80-110 kph 5.5 5.2
  • 110-140kph 7.5 6.9
  • 80-120kph 7.8 7.6
  • 5th gear
  • 80-110kph 7.4 7
  • 110-140kph 8.9 9
  • 6th gear
  • 110-140kph 10.6 11.1
  • 24'C ambient 42'C iat. 29'C amb. 42'C iat
  • 16'C amb. 36'C iat. 26'C amb. 37'C iat
Small benefits here but better overall filling. As for the sound...fantastic. Photos will come soon.
Reactions: michalis
Oct 19, 2019
7
3rd gear
  • 50-80 kph 4.1 3.9
  • 80-120kph 6.7 6.5
  • 4th gear
  • 80-120kph 7.8 7.6
  • 5th gear
  • 80-110kph 7.4 7
  • 110-140kph 8.9 9
  • 6th gear
Lead the way
Στάλθηκε από το CLT-L29 μου χρησιμοποιώντας Tapatalk
Oct 19, 2019
7
Ευχαριστώ πατρίδα! Για ότι καινούργιο θα σε ενημερώνω.
Αν μπορείς στηλε μ τι ακριβός έβαλες θδλω να κάνω έναν πρόγραμματισνο με μερικές αλλαγές για να είναι φωτιά το μικρό.
Gargi
22
9
I have send you p.m.
Gargi
22
9
Gargi
22
9
Everything is custom made. Box is hand made from olive oil tank. Universal silicone tube 70to 75mm. 70mm aluminium tube. And universal cone filter by Simota.
Reactions: mh6f and RainyDay
RainyDay
92
Hi I just installed an intake too. May I ask how you monitor intake temperature? Also where exactly is the cold air venting from? I had a peek in there and I can't see the duct/channel. I'm wondering what I can do to get more air going to it because it does get quite warm to the touch.
