Ghost45
OBDeleven encodings
Aroza
10
I do not have vcds...
Not sure if this has changed but on the prefacelift cars if you turned on the alarm there are no internal sensors so all it checks are
DOORS, BONNET AND BOOT,
Thus you sit in the car and use the key to lock the car, wait for 30 seconds and then open the door from inside using the handle.
Or open the bonnet (which is not possible on the Leon) again after the 30 seconds
Thanks for the 30 sec tip! That did it!
The alarm tweek is confirmed to be working for me to!
Ghost45
61
22
Rome
Fault no basic setting, is most comon fault. Just press window button down(hold 10 sec) then button up to close window(hold 10 sec) then the window "knows" the basic settings.
How many windows are working? 2x front? 2x rear? Not coded means your bcm dont know if the car has powerwindows. It look like the coding is gone, or there is a problem with wirering. Of there is a problem with wirering, you can check this with vcds and do some output tests.
And also dit you do some coding etc? For example activating auto lock functions, comfort closing functions etc?
Verstuurd vanaf mijn SM-G965F met Tapatalk
I have tested also your method to press for 10 and more seconds the windows up and after down all the 4 windows but seems not save the settings.....
i have found in the web this sheet about the same cods of errors that i see in odbeleven ..look here:
https://www.google.it/search?ei=1md...&ved=0ahUKEwiK1rOfnJbkAhVH16QKHWZBDKQQ4dUDCAo
this procedure is for original seat hardware but i tying to see in the odbeleven but i do not able to resove it.
Reactions: TheSwede
Deleted member 103408
Silly question have you cleared the errors first to see if they come back.
Reactions: Ghost45
Ghost45
61
22
Rome
Obviously....but immediatly after the errors come out...
Other thing is that ....i can't opened and close the windows with the button pressed in remote control...
So the problem remained ...unsolved!
at0ny
155
32
Holland
Your link does not work.
Do you know someone witch vcds or vagcan pro?
With vcp you can check the coding.txt its the same option as longcoding. To find if there is a problem in coding.
Holding Window button only works when basic settings is gone. But everything Works. (Fault basis settings missing etc)
Reactions: Ghost45
Ghost45
61
22
Rome
Look the file attached, about the vcds , no actually in the past i used a cracked old chinese cable of vcds now this not run at all in seat ibiza...do not see all the central electrics....i don't know no one near me with theoriginal clable hex for my seat ibiza.
Thanks for all of you for helping!:clap:
  • 6364679716268863938175425.pdf
at0ny
155
32
Holland
Chinese clone dont work on mqb-ao platform. Only oem. I have oem hexv2. I can open everything. But for the ibiza 2019 you need to check adaption, sec code 31347, en then look for "ZV-options" and "funk" options and look for Windows operation. There is a option for activation and also option for activation of menu in car menu for Windows control. (Adjustale)
have you tried running the items in basic settings that are mentioned in your document.
With regards to changes to long coding you only have to search your history or backup files to see if any coding changes have been made.
Ghost45
61
22
Rome
Yes i have tried of course , and i have repeatedly tried many times but nothing happened!
about the backup..yes i have made the backup and i have tried to see the old parameters but seems not showed in the backup..so i don't understand which are the real parameters.
at0ny
155
32
Holland
this is my backup..
but iside there isn't any parameter about the windows..rear..front..left or right
Trie someone to find that have vcds.
I saw in the log you cant see the sub systems? For axampel module 9 bmc has extra sub systems, like dwa sensor, RL(F/H)S, headlights etc. There in the sub component jou can check about the coding.
Here is a part of vcds log of module 9 ibiza 6F 2018 for example. I have a lot of logs of the ibiza 6F from 2017 til new 2019 with VC..
Ghost45
61
22
Rome
@at0ny,
probably the vcds have more power to see the sub central electrics...in obdeleven i can't able to see these sectors!
Probably are hidden...but why?
at0ny
155
32
Holland
Thats why i advise you to find someone who has vcds or vcp. Then you can check the sub systems. Dont know how obd11 Works or why they dont show this, its easy but i prefer vcds. I use this fit about 5 years now and do alot of coding on cars.
Reactions: Ghost45
this is my backup..
That file is fine as it shows all your error codes etc.
When you do a backup file you should get something that looks like this
Control unit: 42 Door Electronics Driver Side
System description: TSG FS
Software number: 5Q4959593B
Software version: 0014
Hardware number: 5Q4959593B
Hardware version: 009
Serial number: 0000084076985
ODX name: EV_DCUDriveSideEWMAXCONT
ODX version: 006001
Backup name: 42 ded 260817
Long coding:
00100220DE01040000001000
Subsystems:
Subsystem: FOND_FHSG_DRV
Long coding: 2D0000
Adaptations:
Production mode:
Production mode:
Window_Regulator_Supplier_Settings_Driver_Side_Rear_1:
Parameter:
000014832B14F0F0F0002000FC7C00140005066401F4320F0007800000073F8000B4000C000C00270050008900D10129017B04040301030703E80BB832050F2D507304049A3C091A36630083E0E7044E5370CA0003000C00AF016E5A01908507D010100014001403842710536D030010800C01FFDFFF0000000A0000000099EC
Window_Regulator_Supplier_Settings_Driver_Side_Rear_2:
Parameter:
0384025814ECFF02020A0202000A0528021E190A0005F6321E0C0002FE0505FB120D00000000FF00000000FF002400191E201E64D8C4F6F1281E32051E00003D041909120E64ECD8FBF61E1432050C0000C802190F161464D8C4F6F1281E320A0C000A280A0A2823050A281E0000000000000000000000000000000000008B98
Patch_Code_Driver_Side_Rear:
Parameter:
00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Window_Regulator_VW_Settings_Driver_Side_Rear:
Param to DOP_22811:
F600F00010190F03F0080014C800000001A401C2096423C823003232019000000000000000860000323CC8004E004D7964643260D36DCF641E320A0A5BD96DCF64143232321400004331303301000000000000000000C4B9
Deactivate production mode:
Reversing_Threshold_Driver_Side_Front:
90%
Reversing_Threshold_Driver_Side_Rear:
90%
Reactions: Ghost45
dj_sa
14
Switch-on driving profile [WORKING]
1. Control Unit 19 (Gateway)
2. Extended Coding
3. Byte 8 (E8)
4. Activate Bit 4
(After this change, Byte 8 will change from "E8" to "F8")
Hi, where would I find the driving profile? Is there a special button? Thanks,
Ghost45
61
22
Rome
Y
yes this encoding need to be build a real button to change the driving mode.. Whiteout this fisic button this coding do not work!
dj_sa
14
Y
Right... presumably, this button needs to be wired in somewhere? Would it default to a button similar to the vRS button on a Skoda?
Is there no bit I can set in VCDS for the current value instead of using a button?
Ghost45
61
22
Rome
Actually in the car without the factory button that select the driving mode need this encoding and the wired button..but i don't know the real electric cables that need to be connected and where is the sub connector...
For this encoding need one big help with someone that have the fr version to see the real electrics cable and their + or - wires
