As always with me, most parts will be available to purchase...I have no need for two double din set ups.If you don’t want the sat nav maybe we can cut a deal![]()
No rears and I've just put the fronts up for sale.Ohhh Recaro's, has it got the rear ones as well?
I can help you recoup the costs.....sell me the engine and turbo
Sent from my VOG-L29 using Tapatalk
What's wrong with that you've got the whole rest of the car!! greedy ha ha
I've heard there's some parts which would benefit from some upgrading ie selector fork arms.Just for my info, when you upgrade the engines this much apart from the Clutch can the stock gearbox cope.
I did a little research on this a while ago and from what I've read they're pretty strong gearboxes.Just for my info, when you upgrade the engines this much apart from the Clutch can the stock gearbox cope.
The forks can simply be bolted back on though which is obviously handy.
Yeah I've read about 4 gear coming off! Ha
