Interior lights Voltage output
mishawel
51
7
Hey, anyone knows how much voltage the interior lights should get? I've tested with multimeter and it showed only 3 volts, think its too low...
The lights are dim aswell
Legojon
I only wanted a remap
5,284
2,713
I'd have voted 12... can you check on the bulb? Not sure about the interior, but the exterior usually have the voltage printed on them.
mishawel
51
7
Checked on the bulb aswell, 3V
I even checked on the connector itself and it showed 3V, I believe it's wayyy too low
Legojon
5,284
2,713
From what I can see, it should be 12v. Something else must be taking the power.
RADIOTWO
486
93
North Derbyshire
It can depend on where you take the reading from and also what setting have you got on the DMM
mishawel
51
7
Sorry but what's DMM?
And I took the reading staright from the electric connector that feeds the whole bulbs unit (only 1 connector for the complete unit)
mishawel
51
7
DMM Digital Multimeter, and what setting did you have on ?
Oh OK
What do you mean by setting?
Just put the dial on DC Voltage and tested
My DMM is a cheap Ebay one, doesn't have volts range (20v/200v etc) just DC/AC options
mishawel
51
7
Thats ok, some people might use the AC setting and just wanted to check. but another test, take the bulb out and
the put the leads across the bulb connections, and see what the voltage is then
Shows 2.7V
Too low I think
mishawel
51
7
I also think that is too low but have you checked any other interior lights, and the boot light are they all the same?
what you need to do is locate the fuse and check the output of that, then find the switch and check that out
Forgot about the boot light, will check it
