Checked on the bulb aswell, 3VI'd have voted 12... can you check on the bulb? Not sure about the interior, but the exterior usually have the voltage printed on them.
It can depend on where you take the reading from and also what setting have you got on the DMMHey, anyone knows how much voltage the interior lights should get? I've tested with multimeter and it showed only 3 volts, think its too low...
The lights are dim aswell
Sorry but what's DMM?It can depend on where you take the reading from and also what setting have you got on the DMM
DMM Digital Multimeter, and what setting did you have on ?Sorry but what's DMM?
And I took the reading staright from the electric connector that feeds the whole bulbs unit (only 1 connector for the complete unit)
Oh OKDMM Digital Multimeter, and what setting did you have on ?
Thats ok, some people might use the AC setting and just wanted to check. but another test, take the bulb out andOh OK
What do you mean by setting?
Just put the dial on DC Voltage and tested
Shows 2.7VThats ok, some people might use the AC setting and just wanted to check. but another test, take the bulb out and
the put the leads across the bulb connections, and see what the voltage is then
I also think that is too low but have you checked any other interior lights, and the boot light are they all the same?Shows 2.7V
Too low I think
Forgot about the boot light, will check itI also think that is too low but have you checked any other interior lights, and the boot light are they all the same?
what you need to do is locate the fuse and check the output of that, then find the switch and check that out
