Open the bonnet and look at the top edge nearest to the windscreen. You should see the two washer jets. Holding on the flat edge of one give it a little tug and it will come loose. If the washer jet only has a water pipe connected to it then it is unheated. If there is also an electrical connector fitted to the washer jet then it is heated.
If you lift the bonnet and look under the lining, you'll see whether or not the jets have an electrical connector attached. Connector = heated, No connector = not heated. If you did want to upgraded to heated ones, I've written a how-to in the guides section
The FR Black, Excellence and Excellence Lux models seem to be the only ones with the winter pack for MY20
Really strange that the Cupra / Cupra Lux isn't being offered with this!
I just fitted this mod on the Mrs Audi A3 and it makes a huge difference. £20 off ebay from Crewe Audi. They were advertised as Audi A6 fan jets. Same parts for all VAG group cars I think
I'll be doing this mod in a few weeks when the new motor arrives
