I'm in the same position as you. Just gone over 8000 miles and still very limited if nothing at all.Iv got 68 plate 290 dsg 7 speed etc and the Same no pops and bangs or farts on the up shift... or over run ... only when the car is hot 106 degrees she starts popping but only very quiet. I’m wondering if by having a res delete it will change????
I've just started figuring out my 65 plate 280 DSG.
Pretty sure it only works in sports mode on the gearbox auto or manual.
Need to be WOT or pretty close and shift up at 6kish rpm on throttle through gears 1-3, its loud as well. I have the engine set to comfort so no stupid soundaktor but I can hear it with music on pretty loud as well.
I just run standard supermarket fuel as well.
If the box is in sport, then the engine is too.
Get yourself carista or OBDeleven and turn the soundaktor off, or unplug it!
Its not its 2 separate things, putting sport mode on will put the engine in sport and the gearbox in sport but you can just knock it out of sport if you want.
If you have it in comfort and knock the gearbox into sport its doesn't change the engine setting.
For clarity, I can confirm that there is a huge difference in the pops and bangs in the 2019 Cupras when changing the driver profile to Sport. I've been driving around with the driving profile set to Comfort for the longest of time, thinking that each time I flicked the DSG into sport it would give me full beans! Little did I realise that you need to change the actual driving profile to Sport to get the full joys, so thank you to you guys!.
I have a res delete and in the Sport driving profile the thing is beautiful; effortless pops and bangs that are pretty damn loud!
Its probably because you're thrashing it more with a more sensitive throttle, or you're getting finnessed by the fake sound!![]()
With Regards to thrashing it, that is definitely not the case. You can sit at about 3k revs and blip the throttle to 3.5k and it'll pop off. I think this is mostly due to the res delete! My mate was walking towards my car from the rear the other day and he said he could hear the thing growling from half way down the road - definitely not fake sound!
I was under the impression the fake sound is only pumped into the cabin when in the Cupra driving profile? I personally dislike the fake noise and never put my baby in Cupra mode.
You be right my friend! Seat been doing me dirty all this time lmao!The Sport and Cupra engine setting is fake sound, just different fake sounds. The only thing any engine setting changes is throttle response and the preset Sport and Cupra are just presets, they dont do anything different from choosing your own set ups in Individual.
Thats what I meant by saying about the throttle response because that is all that is changing when you are changing that setting.
I compiled a bit of info here I found so far.. https://forums.seatcupra.net/index.php?threads/drive-profile-settings-guide.459037/
Seat aren't exactly clear on what stuff does but I think I got to the bottom of most of it.![]()
I love using Cupra mode as it maximises all parameters for sporty driving in engine and DSG box plus the sound of the soundaktor introduces an extra shot of drama for my ears and particularly if riding with a passengerMine pops and bangs particularly loud just like a gunshot going off if going over 3-4k revs and is easily heard within the cabin. When in comfort mode there aren't any at all so there must be something different happening which enables that?
Mine is up to 5k now and definitely farts and pops in sport mode. Nothing in comfort mode. Its not loud, but is loud enough for me, passengers notice it. It also crackles quite a bit in sport mode, even if just blipping the throttle in neutral.
