Only thing i can think of is measuring new and old shocks between the lower spring cup and bottom of the shock. Longer legs?
Don't have the old kit
Looked better height stock![]()
Maybe someone on here with the same age/model could measure theirs for you.Don't have the old kit![]()
Should be able to feel under the shock in the hub as they go right to the bottom.Shocks aren’t fully seated in the hub.
you need to slacken off hub bolt split hub and get them properly seated. I have made this mistake before
Checked with kit supplier to see if wrong parts in the box?
had AP set fitted to my cupra. Horrible. ruined the car.
Most kits lower the rear too much in my opinion, i presume you went the 30/40mm kits to avoid this. i'd be gutted too.
can you take a pic of the top mount in the engine bay, see if they have seated fully. sometimes the fronts settle more and take a time to do so.
There are 2 things which could be at fault, either the springs are too highly rated and causing the ride height to be to high and / or the strut length between the bottom cup where the spring sits and the positive stop at the hub is too long. I had this problem many years ago when I put struts from a 1600 Ford Escort onto a 1300 Escort, damn thing looked like Thunderbird 2 about to take off from it’s launch platform on Tracy Island ( I mean the original Thunderbirds of the 1960’s and Yes I am that old ) hope this may help
You could always try the power flex top mounts that drop the front 10mm
The top mounts are LCR and I think they are supposed to drop it 10mm? Plus they were £100 so not keen on spending more money on top mounts...
Stab in the dark here, but the bottom track control arm, are they the same for all Leon models of your year of manufacture, ie if the model is updated is the track control arm longer from subframe to the bottom ball joint where it connects to the stub axle underneath the drive shaft.
The only other thing I can suggest is to have it stripped down completely, have the spring tested for it’s length when not under compression, then have it tested for it’s compression value at the working under pressure as if on the car, it should have compression values from the manufacturer. If the compression value is higher than that specified then the spring is your problem, on strip down check the positioning of the springs in the top and bottom cup and ensure the end of the springs are located correctly, it would not be the first time I have come across springs being incorrectly located in cups and once under pressure they do not move. Have a look at the second suggestion first before testing the second.
Hope it helps
Andy G
Motto of the day, “Never bin old parts until you’re happy with the new parts”
