Oct 10, 2020
Clutch hasn't been right for a while, kept sticking down a while ago while driving however has been daily ok recently. Yesterday it started clicking when going down and coming back up and today when I've gone to go for a drive it won't engage and just sticks down. I've recorded a video:
I believe it's probably the master cylinder but I could be wrong. Do you guys have any ideas?
I had the same issue with my fr184, not to that extent though, was intermittent. Most of the time (judging by the forums) it’s the slave cylinder, but mine was a failing master cylinder. Worth having a look around the car to see if it’s leaking any clutch/brake fluid and check the reservoir level too. Hopefully you see something otherwise it’s change parts until it’s fixed. Fingers crossed it’s not slave cylinder as that’s box out :confused:
Reactions: X333rn
Luckily no leaks and dot 4 level is high. Ordered a new master cylinder and will be attempting to fit when it gets here. Wish me luck!
Reactions: Jay5959
Aye good luck mate, hopefully that sorts it out. I know how horrible it can be driving and the clutch pedal go on you!
Reactions: X333rn
Just happy it only went on the drive. Meant to be going on a trip in a week ?
That’s lucky, on the drive I mean not the trip next week..........it could be sorted by then though (y). Mine went when joining the m60, to say it was a bit of an inconvenience would be an understatement:LOL:
Reactions: X333rn
For anyone else that has had the same issue, I bled the clutch line and there was A LOT of air in it. Works better now it's been bled but still sticks a little. Will be replacing the master cylinder at the weekend.
