Seat ibiza 6l wipers stopped working
Nov 4, 2020
Hi having issues with my ibiza 6l the wipers have stopped working it happened a year ago same issue the aa wriggled the relay n they came bk to life year later they stopped working again so bought new relay this time.
Not fixed the issue
So were I'm at now is stalk is working as relay is clicking I took out the wiper moter and arms hard wired to battery moves fine so were do I look at next ?
380bhpdaily
1,261
574
Possible the back of the fuse box has melted or the wiring is damaged or loose if it’s not sending signal to the motor
380bhpdaily
1,261
574
Are you able to test the plug on the end that clips to the motor for power?
Is there isn’t then there is a break going from there to the fuse box.
Nov 4, 2020
Gona take it to my bros garage tomorrow and test the wiring no signs of melting or blown fuses maybe broken wire will hopefully find the fault tomorrow
