I need to do that asap myself, it looks like a fiddly job tbhBangin mate. I had wanted to change the gear oil but read nightmares about what type to use etc
Its not the clutch then.
Fingers crossed its just linkage setup.
not a clue, tbh i'd look at the bushes first as mine looked pretty good still. But when i broke the linkage grabber thing i could see wear which would lead to the linkage slowly coming out of alignment over time.Know anywhere you can pick the bushes up. I had a look on eBay there was one set for over 40£
I’ll get on It tomorrow! Hope I have a locking pin and 5mm drill lol
Dog bone.Yeah I’ll look tomorrow. I’ve also noticed when in first or 3rd (only gears I’ve paid attention) if I prod at tw throttle I can feel the knob move back and forth!? Someone said possible engine mounts?
This 100%. The 'thunk' on pull was cured by polybushing the dogbone.Dog bone.
Ive got 2 spare if you need one.
One febi, used for a week
One original with brand new black edition bushes.
For the love of god dont drop the bit inside the gearbox , i bought a pack of 5mm nails and bent the top like he did in the video(stops it from falling through). it was a snug fit but the more snug it is, the more accurate the adjustment.
Make sure you do it in this order:
Unlock the adjuster rings on the gearbox > then lock the gearbox selector out > then lock the shifter knob out.
then you just have to snap the rings back in place, its good to pull a little slack out of it here. and unlock the selector and shifter knob.
What? I didn’t see him bend anythin. But I was battling my daughter to be allowed to watch it
Oof is it an easy swap?!
He doesnt do it in the video, but he uses a nail with a bend in the top to clear the gaitor and prevent it falling through, as the hole goes straight through, so if you used a 4mm drill bit it'd just fall straight through into somewhere under the shifter assembly lol.
