Wattser
47
16
Hi all,
I have yet to receive my Formentor VZ2 which is due for March delivery at the mo. I forgot to test the reverse camera during my test drive (prior to lockdown) and my nearest dealer is currently closed. Whilst reversing (my current car is a Merc) I can switch the camera so it shows oncoming traffic from either side of the vehicle. Does the Formentor reverse Cam has similar capability? Any advice would be much appreciated. Thanks
Reactions: jcbmally and Syphon
I can switch the rear view camera to show oncoming traffic from either side of the my car for when I am reversing out onto busy roads etc. I was wondering if the Formentor has a similar camera system. Thanks
The Formentor has radar in the rear bumper that picks up oncoming traffic when reversing, when it does a "bong" noise is heard. The camera is wide angle and looks a bit weird at first but you do see traffic. You can change some settings depending on whether your parking parallel or in a bay, but it isn't 360 view.
Reactions: Wattser
Thanks for this. Sounds like I have nothing to worry about. Cheers
Reactions: jcbmally
is the camera a nice clear image ? my BMW is very good a lot better than my golf R mk 7 i had .i am hoping the formentor is better than that or at least as good as the BMW.my car is on order .
I’m very impressed with the camera quality, much better than my Nissan Leaf one. I also love that it has its own washer jet when activating the rear window washer. All vehicle cameras should have this IMO.
I am not that impressed with the camera. I have switched from a Merc CLC and the camera on the Merc was much much better with a clearer image quality.
Yes, it's definitely worse than in my last Mercedes, which was also 360. But it's not far off from standard Audi camera from 2017. Fish eye mode is quite useful for reversing out of parking spot in busy supermarket.
Reactions: Wattser
cheers for the info will have to wait and see,there was a picture put on here of a dashcam image and that was clearly a broken/faulty camera it was shocking.
looked like someone had smeared Vaseline over the lens.
Its not that bad, but it could be better, I'll upload an image for you in 5 mins
Reactions: ninja_geezer
Bigger problem is at night. Rear light is not strong and you lose a lot of visibility. I guess that is to be expected.
What I do like about the camera is that you can switch to fish eye mode and you are able to effectively see 180 degrees - very useful for reversing out and peeking - I know the car has warning for traffic but it eases my mind to be able to see it. This fish eye mode is not immediately obvious as the options are hidden, move your hand close to the screen and the buttons will appear (can be seen in the photo Wattser shared).
Cool .thanks
I didn't know about the fish eye, thanks for the info
Yes the Formentor has this type of camera, If your car has one fitted. You can switch between 2 views (3 if you have a genuine towbar)
VWAG have had this feature in their cameras for a fair few years
Area view (360° cameras) is now an option on the Formentor.
Depending on the trim level, you may also have blind spot assist meaning radar in the rear bumper. This can detect oncoming vehicles whilst you're reversing or as you're planning to open your door after parking
We can also retrofit it for those who missed out on the option
