Has anyone successfully done one of these themselves ?
How did you get on ? Did it, 100% success
Did you drain the mechatronic unit also ? (as per workshop manual) - Yes
Did you unscrew the overflow pipe 2 turns during the fill procedure ? (as per workshop manual) - No Red fill pipe doesn’t get loosened 2 turns, it’s a shorter pipe. See page 229 of the OGC 2020 workshop manual linked below.
What torque did you use on the oil filter housing ? (workshop manual states 50nm which seems high) - Yup it was 50nm
I'm getting the parts together to do it myself, i've watched dozens of youtube videos but sadly there isn't any for this particular gearbox which is the 7 speed DQ381 with code 0GC and there is some crucial differences on this gearbox versus the 6 speed or 7 speed DQ500 boxes that there is loads of videos for. - Update couple of good vids linked below
Firstly, the oil filter is horizontal on the DQ381 and not vertical like every other box, and also comes with a heat shield.
The workshop manual states it gets torqued up to 50nm which is 30nm higher than every video and guide for the other boxes - It is 50nm see attached manual, also make sure you put plenty of rags around it as oil will spill out over the gearbox. For access I just removed the air intake pipe
Secondly, the manual states that you drain the mechatronic unit as well the main oil during the drain procedure. But doesn't show you how to fill it - so it must get filled in the normal fill procedure, is this correct ? - Yep drain this as well and it gets filled when you fill the main section.
FYI Here is a list of parts i've collected so far for doing the procedure.
Oil 6 litres - G055529A
Oil Filter - 0GC325183A
Oil filter O-ring- N91084501
Drain plug washer - N0438092
Drain plug - N90215404 (can be reused)
Mechatronic drain washer - N0138132
Mechatronic drain plug - N90965401 (can be reused, but I nearly striped the thread off mine, it’s was tight, will need a new one next time)
Oil filler VAS6262 - (I didn't get this instead made a DIY system from a 5L garden sprayer and a DSG fill adapter off eBay, pic below)
DSG fill adapter - https://www.ebay.co.uk/itm/18546087...-ZJdOpBTxO&var=&widget_ver=artemis&media=COPY
Decent set of hex bits for the drain plugs and torque wrench for the filter, see the Vids below for what sizes I can’t remember.
OBD11 (or VCDS) to check oil temps during filling procedure and reset adaptations afterwards
EDIT++ Update on some bits here
Latest OGC geabox manual
"7-speed-dual-clutch-gearbox-0gc-eng-2020"
drive.google.com
Couple of pretty good youtube vids of the procedure
or this one, bear in mind hes got it wrong regarding the Red fill pipe (based on the latest manual posted above) but the rest is pretty good.
7-speed-dual-clutch-gearbox-0gc-eng-2020.pdf
drive.google.com
