Mozboosted
2002 Cupra stage 2
Jun 7, 2021
22
7
42
Morpeth
Got all these codes, car won't start turns over no problem, sounds like fuel pump kicks in with ignition.
Got an oil light so I changed fluids alongside level sensor and sump plug, I've also fitted new oil pressure switch, but having no luck, I have the torque app and a few others as I bought an obd2 bluetooth device it connects but it won't connect to ecu. 2003 Leon Cupra.
Amazed, thank you guys, I'm going to charge my battery again and see what's wrong, I have no idea how to use these tools I just found 1 in a car I bought assumed it stored codes as my ep3 had alot of the same things appear.
Im truly greatful, I've tried searching for weeks for a solution.
Ill update as soon as I've run my erronds and have battery time to charge.
No probs mate, let us know what codes you get.
Reactions: Mozboosted
Well it seems after, oil pressure sensor, full service, fuel pump relay, fuel filter, crank sensor, oil level sensor, battery, plugs etc etc upon removing my ecu it was found that she decided to go swimming without her arm bands.
Sent away for some work to a lad in Norwich who will clone my map and immob settings and hopefully I'll be able to give her a lovely cruise next week.
Since she's not been driven for over 4 months, I'm gonna do another full service with new filter and oil, and I'll replace the oil pump also. And keeping her out of boost for the first tank of fuel and below 5500rpm for the second so she can be worn back in nice and slowly.
Will update when new ecu arrives.
First start and she's running again. Gonna take her slow, I'm assuming now there's no oil light coming on (car ran for around 10-13minutes I revved to 3500rpm) so got it up to temps, surely it would have come on in that time if any issue?
I will be fitting a new pump and pick up anyway as I bought one and let it sit in degrease for 24 hours, new pick up pipe seal fitted. Just need rear tire inflated so I can take her for our first drive together. 5 months almost...
Speak to Justin, fantastic team. Had me sorted 5 working days from me posting my ecu to be cloned.
Well took her out today done a handful of miles. 25 or so, and she is fantastic to drive she feels real solid for a car that's done 167k honestly feels as solid as my old pro ceed when she hit 30k. I'll honestly be shocked if anythings needed for the MOT in 2 weeks time. Although I do have a boost leak somewhere so I'll be looking and diagnosing that ASAP, fella before me done a shady job at sai n75 delete or whatever they are, I'll get a few pictures tomorrow, sai is definitely gone and the bit above the exhaust manifold.
But again I'm a Honda guy usually but both Leon's I've had were 2002 with my pd130 being 140k and she felt real solid too.
Definitely keeping this one though. Rolling road in 4 weeks for power charts.
Reactions: mty12345
Yup! It is a solid car, once you keep the water out.
