Nov 12, 2019
Hi, new member here.
Had a search for a similar issue and found many heater issues but nothing like I am experiencing on my 2013 Leon 1.6tdi.
From this forum, I am thinking about buying a diagnostics tool (carista etc.) to see if I can work out the issue. Is this possible?
My Problem:
Blowers\Heaters seemed to be working at 80-90% power (compared to when new) for many months.
Didn't think an issue. Had my aircon re-gassed as the cold A/C dropped considerably.
Then after a month or so, could not have heater or A/C on over setting "2" without making a noise switching off
Then stopped working altogether
Now, intermittently on/off (mainly off) and around 20% power and neither hot/cold
If anyone can provide any pointers it would be much appreciated. Read about heater matrix, pressure switch but my above symptoms didn't seem to fit.
My Problem:
So if you had the blower speed above 2 it would make a noise? Presume you mean the blower fan would be noisy? What sort of noise?
I would be checking the blower fan first. Easy enough to undo a few torx screws and drop the blower motor to inspect - and check the blades turn freely.
Reactions: mk3leontdi
Blower fan would be my first check due to noise, bearing dying? usually when the rheostat fails it defaults to full speed only.
Thanks, will check blower motor / resistor as a start.
If that doesn't fix it, the threads on here seem to suggest the air con pressure switch as the next check.
At the moment no speed at all, heater/ac seems completely dead.
