Fog lights flash with indicators
Jul 24, 2022
Hi there guys hope everyone is doing well... Now for my question does anyone know how to code fog lights to work with the indicators soo basically when I indicate in a certain direction the fog light flashes with it.
Any help would be appreciated. Hope everyone has a good dayšŸ˜Š
Thank you
martin j.
1,996
891
Fife
Asked a mate, he thinks it would create an MOT issue, something he would need to look in too, but, just in case itā€™d be a fail.
Reactions: RUM4MO
rafletcher
531
214
Thank you
That would be illegal.
black_sheep
1,256
586
I was just about to post the same as @martin j.
In summary, yes it would be possible via coding - fronts only as there is only a single fog bulb in the rear cluster.
Also, pre-FL or FL and model will make a difference to coding.
However, why? What are you trying to achieve?
Jul 24, 2022
I just want it for style as I've seen it on mk7 golf gtd and it looked quite good and before it goes for the mot I'd remove it and restore it back to normal via vcds
Jul 24, 2022
Its a pre facelift model 2014 leon fr and What I am trying to achieve is when I turn the left/right signal on for the fogs to flash with it. Thank you
H Rafiq
936
372
You can do it with an ODB. Personally, Iā€™m not a fan. Iā€™ve even deactivated my DRLs šŸ‘€
Glosphil
419
182
Gloucestershire
Why turn off DRLs? They are a safety feature. Illegal to de-activate? If you car is after 01/03/2018 it will fail MOT if DRLs are not working.
H Rafiq
936
372
Why not? You can't see them when you're driving. Other driver's can - which is the whole point.
My 2018 Leon also has the rear sidelights always on - excellent idea.
I just donā€™t. I donā€™t see the point of having lights on the whole time the cars on. My auto lights come on early, before itā€™s dark dark. And my cars white anyway so easy to spot. Shouldnā€™t need DRLs on to spot me in daylight.
BigJase88
Jase
Apr 20, 2008
3,767
1,069
The cornering fog function is not illegal and comes as standard on newer cars.
Get a carista dongle and you can change it on that via an app on your phone.
Cost Ā£9.99 a month but you can cancel after you have enabled it
SteveGSXR600K1
579
189
I used Carista to turn my rear DLR's on all of the time. Nice little feature.
I can't remember if we've talked about this before, but from the inside, do you get the two red LED lights on above the rear view mirror on all the time? Also things like the centre console buttons being lit all the time.
black_sheep
1,256
586
Using VCDS there are two different ways to code the lights. An auto version which causes the submarine lights to activate. However it is possible to activate each light separately to do this. Iā€™m out today, but will link a couple of posts/webpages that will help:
Look for ā€˜daytime running lights with tail lightsā€™.
Yern
629
312
I liked that on my Mk 3.5 FR the rear LED lights always on, Mk 4 only when the sensor detects darkness. :( .
